POV-Ray : Newsgroups : povray.newusers : Re: Howto create a light fading completely dark at distance? Scene attached Server Time
14 Oct 2025 10:36:55 EDT (-0400)
  Re: Howto create a light fading completely dark at distance? Scene attached (Message 1 to 2 of 2)
Subject: Re: Howto create a light fading completely dark at distance? Scene attached
Date: 31 Aug 2004 17:35:00
Message: <web.4134edd178966cd1546e776f0@news.povray.org>
I suppose this is caused by the fact, that the light source (latern) is
near the camera's position and there is not much light reflected
BACK TO THE VIEWER. Much more light is reflected from surfaces
vertikal to the viewer. I experimented with different fade_powers,
falloff and light intensity, but the floor was still too dark.
So a added a spotlight pointing from above vertical to the floor to
make it brighter.
This creates the fading light effect much better than the fading point
light.
However, you must take care, that the light cone of the spotlight does
not touch a pillar (a vertical surface facing the viewer), because
this destroys the illusion, that the light on the floor is produced
by a light source (the latern) near the viewer.
If the spotlight touches a pillar the viewer can see, that the light source
producing that sort of shadows cannot be the latern, but is coming from
above.
(Sorry my native language is not english).
Date: 8 Sep 2004 13:55:01
Message: <web.413f464378966cd148cbffb00@news.povray.org>
I had a look at your code,
Im only new to pov but had a quick stint with lightwave a few yrs ago.
heres what i did.
First the global ambiant settings need to be set at 0 or just under .01 etc.
then the diffuse and ambiet levels of the scene objects need to be set at
about 6 or 7 .
next set the light under the camera close to the ground  and make it an area
light.
now take a cone or similar object add a filtered gradient to it ,make it
hollow and stick the light inside it.
move the camera and light on the same path abd you have a moving light
source.
the floor texture was too dark to really use so i changed it and made the
coloums cleaner to speed the render.
this is an example of what you can do with this light.
the shadows all fall away from the camera.
this is just a really messy work around using your code.
cleaned up a bit,
Im rendering an animation now so it will be inthe binary animation section,
called darkwood flight.
sprocket.(need a good povtag?)
source for dark forrest.(no animation values)
[START]
global_settings { //  sets an overall brightness/ambient light level in the
scene
  ambient_light color rgb -.001}
 // user settings
here!!!!!!!-------------------------------------------------------------
 #declare ld=5; //lantern distance   higher is shorter distance. lower is
further away  [1....15]
 //   !17 does weird things!!!!!!!!!
 #declare dt= 4; // array size for k i settings later. num trees   [10]
 #declare vect1 =  <27.0, 1.5, -1.0>;
 #declare vect2 =  <27.0, 0.0, -3.0>;
#include "stones.inc"
#include "textures.inc"
 background { color Black }
#declare texbot=texture{T_Stone18 scale 4};
#declare texcols=texture {PinkAlabaster scale 0.2};
#declare DragonEggHolder=
 union {
  difference {      // Steg
   cylinder { <-1.0,-0.2,0.0>, <0.0,-0.2,0.0>, 0.1 }
   sphere { <0,0,0>, 0.43 scale <1.0,1.3,1.0>}
  intersection {    // spherical holder
   difference {
    sphere { <0,0,0>, 0.50 }
    sphere { <0,0,0>, 0.43 }
   box{ <-0.5,-0.5,-0.5>, <0.5,0,0.5> }
   scale <1.0,1.3,1.0>
  translate <1.0,0.5,0.0>
  texture {texcols}
#declare DragonPillar=
 union {
  #local maxy=60;
  #local yh=1;
  #local ystep=1.0;
  #local w=0;
  object { cylinder { <0,0,0>, <0,maxy,0>, 0.4 } texture{texcols} }
  #while ( yh < maxy )
   object { DragonEggHolder rotate w*y translate yh*y }
   #local yh=yh+ystep;
   #local w=w+75;
   #if ( w >=360 )
    #local w=w-360;
#declare DragonPillarWood=
 union {
  #local i=0;
  #local k=0;
  #while (k < (1*dt))
   #while ( i < (1*dt) )
    object { DragonPillar
    translate <i*8, 0, k*7+sin(i*k)> }
    #local i=i+1;
   #local k=k+1;
   #local i=0;
 plane { y,0 texture{pigment {
 marble  color_map{[0  rgb<0,.7,.2>][1 rgb<0,.3,.1>]}turbulence .9 scale 3}
 finish{ambient .5 diffuse .5 reflection .23}normal{bumps .5 scale .1}}
 object {DragonPillarWood finish {ambient .13 diffuse .1}}
#declare man=union{      // lantern and area spotlight
// WARNING: This special light can significantly slow down rendering times!
light_source {
  0*y                 // light's position (translated below)
  color rgb <.5,.5,.3>
  //spotlight
   // radius 33
   // falloff 180
   // tightness 100
   // light's color
  area_light
  <1, 0, 0> <0, 0, 1> // lights spread
  2, 2                // total number of lights
  adaptive 1
  jitter
  circular
  orient
  translate vect1 translate<0,-0.84,-0.0>
 //  point_at vect2
fade_power ld/1.2 fade_distance 17-ld
object{ man}
  location vect1
  look_at   <-22.0, 5.0,  66.0>
translate<0,.2,0> angle 90}
//shade for lamp stops litegoing up trees.
difference {
    sphere { <0,0,0>, 0.50hollow }
    sphere { <0,0,0>, 0.3 hollow }    scale <.9,.5,.9>*2
    no_reflection       //no_shadow
   translate vect1 translate <0,.2,0>pigment {
    gradient x  scale .5
    color_map {
      [0.00 color rgbt .9]
      [0.1 color rgbt.8]
      [0.2 color rgbt .7]
      [0.3 color rgbt .6]
      [0.4 color rgbt .5]
      [0.5 color rgbt .4]
      [0.6 color rgbt .3]
      [0.7 color rgbt .20]
      [0.8 color rgbt .0]
      [0.9 color rgbt .0]
      [1.00 color rgbt .0]
    } rotate <0,0,90>
translate<0,-.8,0>}
[END]
