POV-Ray : Newsgroups : povray.newusers : texture_maps and patterns Server Time
17 Jan 2026 16:31:50 EST (-0500)
  texture_maps and patterns (Message 1 to 4 of 4)
Subject: texture_maps and patterns
Date: 4 Aug 2004 06:55:00
Message: <web.4110bfef1de0e849cf668310@news.povray.org>
#declare foo = function {
   pattern {
     checker
    foo       //replace built-in pattern with previous declaration
    texture_map {
      [0.3  pigment{Red} finish{phong 1}]
      [0.3  T_Wood11]    //this is a texture identifier
      [0.6  T_Wood11]
      [0.9  pigment{DMFWood4} finish{Shiny}]
The above are taken from the documentation. Thanks in advance
Subject: Re: texture_maps and patterns
Date: 4 Aug 2004 07:05:00
Message: <web.4110c1b3e77d62b5cf668310@news.povray.org>
For some reason the following was deleted from the start of my post:
"I want to use a texture map with a user-defined pattern function (as
opposed
to the in-built ones). Is this possible? The texture_map documentation
seems to imply that the pattern you specify is simply a function, and the
documentation on patterns says you can define pattern functions, but when
I've attempted to put the two together the parse fails with an 'expected
pattern, found function' error. Is it shoddy syntax or am I trying to do
the impossible?"
Date: 4 Aug 2004 07:10:14
Message: <4110c416@news.povray.org>
  The correct syntax for that line is:
      function { foo(x, y, z) }
Date: 4 Aug 2004 07:30:00
Message: <web.4110c83be77d62b5cf668310@news.povray.org>
Thanks. Thought it would be something that simple.
