POV-Ray : Newsgroups : povray.newusers : Problem with transparent isosurfaces Server Time
21 Mar 2026 04:37:07 EDT (-0400)
  Problem with transparent isosurfaces (Message 1 to 2 of 2)
Subject: Problem with transparent isosurfaces
Date: 31 Jul 2004 16:40:00
Message: <web.410c03689d7ab8b4715142740@news.povray.org>
I am currently trying to render a semi-transparent spherical isosurface. I
set a pigment with a transmission value of 0.75, however when I render the
image the color on the surface of the isosurface becomes transparent but
all that remains is a solid black form of the isosurface, which does not
seem to resond to any transparency value I set.
Subject: Re: Problem with transparent isosurfaces
Date: 31 Jul 2004 17:08:13
Message: <pXrZqDAdoADBFwjl@econym.demon.co.uk>
have you checked the Messages pane to see if it mentions the
max_gradient setting?
I suppose that it's possible that several layers of your isosurface are
in line of sight, so you may need to adjust max_trace or
max_trace_level.
Mike Williams
Gentleman of Leisure
