POV-Ray : Newsgroups : povray.newusers : Odd texture artifacts Server Time
30 Sep 2024 14:18:28 EDT (-0400)
  Odd texture artifacts (Message 1 to 4 of 4)
Subject: Odd texture artifacts
Date: 23 Jul 2004 23:30:00
Message: <web.4101d717e7ea1bd6aed149a60@news.povray.org>
I am rendering the following file and POV-Ray for Windows 3.6.0.id8.win32
and am getting really weird artifacts in the texture.  Anyone else seeing
the same thing?  Anyone have an idea of the cause?
===8<===8<===8<===8<===8<===8<===
camera{
        sky z
        location -5*y
        look_at 0
background{ rgb 0.5 }
#include "functions.inc"
isosurface {
    function { f_torus(x, y, z, 1.6, 0.4)-f_noise3d(x, y, z) }
    contained_by { box { -2, 2 } }
    material{ texture{ pigment{ rgb 1 }}}
light_source{
        <3,-3,3> color rgb 1
Subject: Re: Odd texture artifacts
Date: 23 Jul 2004 23:54:49
Message: <4101dd89$1@news.povray.org>
"Alex Wollangk" <ale### [at] tdsnet> wrote in message
news:web.4101d717e7ea1bd6aed149a60@news.povray.org...
You should use max_gradient in the isosurface. If you read the warning
message POV gives you, after rendering without it, you'll see that it
suggests what value to give that. Check the documentation for isosurface and
you'll find out more about that. A value of around 1.6 should clear it up,
although I noticed its shading still had speckles so I'm not sure what it
would take to make those go away.
Bob H.
Date: 24 Jul 2004 09:50:01
Message: <web.410267fe6a733d77aed149a60@news.povray.org>
Ah.  RTFM ("Read the ***** message") :)
That did it...
Although the first time I rendered it, it told me that I should use a
max_gradient of 1.549.  I set it to 1.55 and rendered again and it told me
that I needed 1.635.  Hmmm...  Setting it to 1.64 eliminated any warnings.
Thanks,
Alex
Date: 25 Jul 2004 09:09:11
Message: <4103b0f7@news.povray.org>
In article <web.410267fe6a733d77aed149a60@news.povray.org> , "Alex Wollangk"
What you get is only an estimate.  To determine the exact value to first
time would require to always render assuming an infinite maximum gradient.
Also note that the value reported may change if you render with a higher
resolution because more samples may find places in the function needing a
different maximum gradient.
    Thorsten
e-mail: tho### [at] trfde
