POV-Ray : Newsgroups : povray.newusers : Photons Server Time
30 Sep 2024 16:18:51 EDT (-0400)
  Photons (Message 1 to 5 of 5)
Subject: Photons
Date: 3 May 2004 14:25:01
Message: <web.40968d72d4d8861bb90c55f80@news.povray.org>
I'm new to POV-ray, and I can't get photons to refract through the glass
cylinder. Check out the programming language below, and see what I did
wrong.
#include "textures.inc"
#include "finish.inc"
#include "glass.inc"
global_settings {
  photons {
    count 20000
    autostop 0
    jitter .4
  location <0,5,-10>
  look_at 2
light_source {<1000,1000,-1000>White
  photons {refraction on
           reflection on}}
background {rgb<.7,.7,1>}
plane {<0,1,0>,-1
  texture {pigment {
    granite
    turbulence 1
      pigment_map {
        [0, rgb<.2,.1,0>]
        [.5, rgb<.5,.3,.1>]
        [1, rgb<.8,.5,.2>]
  finish {ambient 1}
lathe {
  cubic_spline
  6,
  <1,0>,<1.1,0.1>,<1.1,4>,<.5,5>,<.3,7>,<.2,7.5>
  texture {pigment {Col_Glass_Beerbottle}}
  finish {ambient .3
          specular .5 roughness .01
  translate 0
lathe {
  cubic_spline
  4,
  <.95,.01>,<1.05,.15>,<1.05,3.9>,<.95,4>
  pigment {Brown}
  finish {ambient .1}}
object {
  cylinder {<4,4,0>,<4,0,0>,1
  pigment {White filter .75}
  finish {ambient .15
          diffuse .5
          reflection .25
          /*irid {.3
                thickness .1
                turbulence 0}*/
} interior {dispersion 1.1}
} photons {
    target 2
    refraction on
    reflection off
    collect off
Subject: Re: Photons
Date: 3 May 2004 15:23:36
Message: <40969c38$1@news.povray.org>
"CFM" <nomail@nomail> wrote in message
news:web.40968d72d4d8861bb90c55f80@news.povray.org
> glass cylinder. Check out the programming language below, and see
don't forget to include the ior in the interior statement, for glass it is
1.5 ish
T
Date: 3 May 2004 17:53:21
Message: <4096bf51$1@news.povray.org>
The Afro nous apporta ses lumieres ainsi en ce 2004/05/03 15:23... :
>1.5 ish
>T
Water ior around 1.3 to 1.4 for fresh to salt water.
Also, increase max_trace_level to around 12... That's the level I had to
use to get rid of the warning. You have an ambient value of 1 for the
ground, it hides the effect of the photons. Lower is or let it at the
default value and increase the diffuse value if the ground is to dark
(you may also lighten the colour map).
Date: 4 May 2004 09:07:28
Message: <40979590@news.povray.org>
  I thought no warning is given if you explicitly specify a max_trace_level
(any value).
  And besides, it's not a question of getting rid of the warning. It's
a question of image quality vs. rendering speed ratio. If your image
looks good with a max_trace_level of 2, then by all means use it.
Date: 4 May 2004 16:45:00
Message: <web.4098002477466b42f1c8a6e90@news.povray.org>
I'll have to post elsewhere in the newsgroups because I need to post the
image of my sphere, and compare it with an ideal image I'm trying to
emulate. I'm still not getting the desired effects of refraction, and even
reflection. The prism barely shows at all.
