POV-Ray : Newsgroups : povray.newusers : Broken Stone Server Time
11 Apr 2026 00:01:19 EDT (-0400)
  Broken Stone (Message 1 to 3 of 3)
Subject: Broken Stone
Date: 28 Apr 2004 01:10:01
Message: <web.408f3b87a5f405d44e6ccf840@news.povray.org>
Hi, I'm still kind of a new user, I've been goofing around with POV on and
off for awhile.  I was just wondering what the best way would be to go
about giving an object that is made of stone, a broken/chipped look.  Not
necessarily from errosion, but from using a chisel to mold the stone,
having little cracks and indentations.  The object is just made from this:
difference{
cylinder {
  0*x,  .75*x,  1
  rotate y*60
  texture { T_Grnt25 }
cylinder {
  -1*x,  2*x,  .4
  rotate y*60
I'm looking to give the outer side the chipped look.  I was thinking using
splines inside the difference bracket, but I didn't know if there might be
any easier way.  Thanks!
Subject: Re: Broken Stone
Date: 28 Apr 2004 04:20:58
Message: <408f696a@news.povray.org>
"SkinRock" <ski### [at] skinrockcom> wrote in message
news:web.408f3b87a5f405d44e6ccf840@news.povray.org...
> difference{
> cylinder {
>   0*x,  .75*x,  1
>   rotate y*60
> cylinder {
>   -1*x,  2*x,  .4
>   rotate y*60
I wouldn't try CSG to get the broken look. Depending on resolution, either use
normals (if high res. not needed) or make your object an iso-surface (for high
res.).
If I get some time later, I'll post an example of each.
Date: 28 Apr 2004 17:37:28
Message: <40902418$1@news.povray.org>
SkinRock nous apporta ses lumieres ainsi en ce 2004/04/28 01:05... :
>difference{
>cylinder {
>  0*x,  .75*x,  1
>  rotate y*60
>cylinder {
>  -1*x,  2*x,  .4
>  rotate y*60
If you only have a, very, few chips (less than 10), you /may/ use some
small boxes to chip into your cylinder.
If you want chipping all over the surface, you are way beter with the
suggestion of Tom Melly.
Tip: when you want the same texture or transformation for all parts,
place it at the end like:
difference{
    cylinder{0*x, 0.75*x, 1}
    cylinder{-0.1*x, 0.76*x, 0.4}
    texture {T_Grnt25} // apply the texture once to the whole object
    rotate 60*y // rotate the complete object at once
    translate <x, y, z> // some displacement
Cleaner, easier to read, less prone to errors, use less memory, is
faster ro write, parse and render.
