POV-Ray : Newsgroups : povray.newusers : Problems intersecting a transparent sphere and a box with an image Server Time
15 Oct 2025 10:22:50 EDT (-0400)
  Problems intersecting a transparent sphere and a box with an image (Message 1 to 5 of 5)
Subject: Problems intersecting a transparent sphere and a box with an image
Date: 24 Dec 2003 08:00:02
Message: <web.3fe98d837589c98b7dec0c820@news.povray.org>
In my quest to generate some decorations for a Christmas card, I want to try
to create ornaments with pictures of my kids in them. Originally, I wanted
the picture on the ornament but it doesn't look good. So now, I'm trying to
get the picture to look like it's inside the ornament. The ornament itself,
I want it to look like see-through glass. Well, it ain't working. I thought
intersection{} would give me what I want but not quite. This is what I have
so far:
#include "shapes.inc"
#background { color <1.000,1.000,1.000> }
    location <0, 2, -3>
    look_at  <0, 0,  0>
light_source { <2, 4, -3> color White}
#declare redBall =
sphere {
    <0,0,0>,1
        color rgbt <1,0,0,0.1>
    finish{phong 1 diffuse 0 ambient 1}
#declare alekoFrame =
box{<-1,-1,0.01>, <1,1,.01>
    texture{
        pigment{
            image_map{
                png "aleko.png"
    finish{diffuse 0 ambient 1}
    //scale 5
    //translate <-100,-100,250>+265*z
#declare alekoBall = intersection{
    object{
        alekoFrame
    object {redBall}
object {alekoBall}
I'm seeing a few problems:
- I don't see the sphere at all (with the phong). I basically just see a
clipped circle with the picture
- My picture appears four times, I guess once for each 1x1x1 box. How do I
make it appear once, but take up all the space of the box? And I only want
it on one side of the box.
- My picture appears speckled. I'm not sure what that's all about. By
speckled, I mean that it looks like a bunch of random pixels have been
removed from the picture.
- My ball doesn't seem very 3D-ish and neither does it look very
see-through... I see that changing ambient to 0 gives a better spheric look
to the ball. But still not very see-through-ish. Maybe I need to put some
kind of textured background to get the effect I want. I'll look into that.
I see that using rgbf instead of rgbt helps also.
If you have some pointers for me, I'd appreciate it much.
Thanks!
L
Subject: Re: Problems intersecting a transparent sphere and a box with an image
Date: 24 Dec 2003 15:24:07
Message: <6haWEDADWf6$EwhH@econym.demon.co.uk>
Instead of a simple intersection, I think you want something like this:
#declare alekoBall = union {
  object {redBall}
  intersection {
    object{alekoFrame}
    object {redBall}
As you surmised, one copy of the image fills the region between <0,0>
and <1,1> whereas you probably want it to fill the region between
<-1,-1> and <1,1>. You can translate and scale it like this:-
        pigment{
            image_map{
                png "aleko.png"
            translate <-0.5,-0.5,0>
            scale 2
Try adding "interpolate 2"
        pigment{
            image_map{
                png "aleko.png"
                interpolate 2
            scale 2
I'm not sure what sort of look you're aiming for, but it might be worth
trying some of the glass finishes and interiors from glass.inc
#include "glass.inc"
#declare redBall =
sphere {
    <0,0,0>,1
        color rgbt <1,0,0,0.5>
    finish{F_Glass7}
    interior {I_Glass4}
Mike Williams
Gentleman of Leisure
Date: 24 Dec 2003 20:53:18
Message: <pan.2003.12.25.01.53.16.836283@videotron.ca>
>   object {redBall}
>   intersection {
>     object{alekoFrame}
>     object {redBall}
Hey, yeah! This looks much better!
>         pigment{
>             image_map{
>                 png "aleko.png"
>                 interpolate 2
>             scale 2
Nope, I still see the speckles. At one point, I had used something like
this (grabbed from another message):
box{0,<1,1,.1>
        texture{
                pigment{
                        image_map{
                                jpeg "man2_template.jpg"
                                //[IMAGE_MAP_MODS...]
                finish{diffuse 0 ambient 1}}
    scale 100
    translate <-50,-50,250>+265*z
and it didn't have this problem. THe problem started showing up when I
made my image much smaller (I guess). Is that what it is? My image is
682x403.
Yep, that's what I was after! Thanks!
L
<Laurent Duperval> ldu### [at] videotronca
Anger is a condition in which the tongue works faster than
the mind.
   --- Anon
Date: 28 Dec 2003 01:30:01
Message: <3fee7869$2@news.povray.org>
Laurent Duperval <ldu### [at] videotronca> wrote in message
news:pan### [at] videotronca...
<snip>
> 682x403.
Try changing one of the z values in box{<-1,-1,0.01>, <1,1,.01> } i.e.:
  box{<-1,-1,-0.01>, <1,1,.01> }
See if that helps.
RG
Date: 28 Dec 2003 20:10:08
Message: <pan.2003.12.29.01.10.07.864717@videotron.ca>
> See if that helps.
Yes, that's it! It must be the problem mentioned in the tutorial where
points that intersect too closely can give weird results.
Thanks!
L
Life is fraught with opportunities to keep your mouth shut.
