![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In my quest to generate some decorations for a Christmas card, I want to try
to create ornaments with pictures of my kids in them. Originally, I wanted
the picture on the ornament but it doesn't look good. So now, I'm trying to
get the picture to look like it's inside the ornament. The ornament itself,
I want it to look like see-through glass. Well, it ain't working. I thought
intersection{} would give me what I want but not quite. This is what I have
so far:
#include "shapes.inc"
#background { color <1.000,1.000,1.000> }
location <0, 2, -3>
look_at <0, 0, 0>
light_source { <2, 4, -3> color White}
#declare redBall =
sphere {
<0,0,0>,1
color rgbt <1,0,0,0.1>
finish{phong 1 diffuse 0 ambient 1}
#declare alekoFrame =
box{<-1,-1,0.01>, <1,1,.01>
texture{
pigment{
image_map{
png "aleko.png"
finish{diffuse 0 ambient 1}
//scale 5
//translate <-100,-100,250>+265*z
#declare alekoBall = intersection{
object{
alekoFrame
object {redBall}
object {alekoBall}
I'm seeing a few problems:
- I don't see the sphere at all (with the phong). I basically just see a
clipped circle with the picture
- My picture appears four times, I guess once for each 1x1x1 box. How do I
make it appear once, but take up all the space of the box? And I only want
it on one side of the box.
- My picture appears speckled. I'm not sure what that's all about. By
speckled, I mean that it looks like a bunch of random pixels have been
removed from the picture.
- My ball doesn't seem very 3D-ish and neither does it look very
see-through... I see that changing ambient to 0 gives a better spheric look
to the ball. But still not very see-through-ish. Maybe I need to put some
kind of textured background to get the effect I want. I'll look into that.
I see that using rgbf instead of rgbt helps also.
If you have some pointers for me, I'd appreciate it much.
Thanks!
L
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Instead of a simple intersection, I think you want something like this:
#declare alekoBall = union {
object {redBall}
intersection {
object{alekoFrame}
object {redBall}
As you surmised, one copy of the image fills the region between <0,0>
and <1,1> whereas you probably want it to fill the region between
<-1,-1> and <1,1>. You can translate and scale it like this:-
pigment{
image_map{
png "aleko.png"
translate <-0.5,-0.5,0>
scale 2
Try adding "interpolate 2"
pigment{
image_map{
png "aleko.png"
interpolate 2
scale 2
I'm not sure what sort of look you're aiming for, but it might be worth
trying some of the glass finishes and interiors from glass.inc
#include "glass.inc"
#declare redBall =
sphere {
<0,0,0>,1
color rgbt <1,0,0,0.5>
finish{F_Glass7}
interior {I_Glass4}
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> object {redBall}
> intersection {
> object{alekoFrame}
> object {redBall}
Hey, yeah! This looks much better!
> pigment{
> image_map{
> png "aleko.png"
> interpolate 2
> scale 2
Nope, I still see the speckles. At one point, I had used something like
this (grabbed from another message):
box{0,<1,1,.1>
texture{
pigment{
image_map{
jpeg "man2_template.jpg"
//[IMAGE_MAP_MODS...]
finish{diffuse 0 ambient 1}}
scale 100
translate <-50,-50,250>+265*z
and it didn't have this problem. THe problem started showing up when I
made my image much smaller (I guess). Is that what it is? My image is
682x403.
Yep, that's what I was after! Thanks!
L
<Laurent Duperval> ldu### [at] videotron ca
Anger is a condition in which the tongue works faster than
the mind.
--- Anon
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Problems intersecting a transparent sphere and a box with an image
Date: 28 Dec 2003 01:30:01
Message: <3fee7869$2@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Laurent Duperval <ldu### [at] videotron ca> wrote in message
news:pan### [at] videotron ca...
<snip>
> 682x403.
Try changing one of the z values in box{<-1,-1,0.01>, <1,1,.01> } i.e.:
box{<-1,-1,-0.01>, <1,1,.01> }
See if that helps.
RG
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> See if that helps.
Yes, that's it! It must be the problem mentioned in the tutorial where
points that intersect too closely can give weird results.
Thanks!
L
Life is fraught with opportunities to keep your mouth shut.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
