POV-Ray : Newsgroups : povray.newusers : value testing Server Time
30 Sep 2024 22:15:42 EDT (-0400)
  value testing (Message 1 to 2 of 2)
Subject: value testing
Date: 20 Nov 2003 19:45:02
Message: <web.3fbd5eea7621ac5a4a5634560@news.povray.org>
If I have something which uses random variables, or any other method of
obtaining values where I am unsure what they would be, is there a way to
have these numbers written to a file so I can examine the results?
I have a trace() function picking random points on an isosurface, and I want
to know what the normals are at each point. I need to know what kinds of
averages I get in order to correctly write a macro I'm working on.
Subject: Re: value testing
Date: 20 Nov 2003 23:32:29
Message: <JuuB0CA7IZv$EwuH@econym.demon.co.uk>
The conventional way of doing that is to use #debug, which outputs
string information to the Message pane. As you want to output numeric
information, you'll need to use str() to convert the numbers to strings.
You'll probably also want to use concat() to format the output.
#debug concat("<",str(MyPoint.x,0,-1),","
                  str(MyPoint.y,0,-1),","
                  str(MyPoint.z,0,-1),">\n")
Or you could use one of the formatting macros from strings.inc
#include "strings.inc"
#debug VStr(MyPoint)
#debug "\n"
If you find that you really do need to write the info to a file, then
you'll need to look at the documentation for #fopen and #write
Mike Williams
Gentleman of Leisure
