POV-Ray : Newsgroups : povray.newusers : sparkling objects Server Time
30 Sep 2024 22:12:51 EDT (-0400)
  sparkling objects (Message 1 to 8 of 8)
Subject: sparkling objects
Date: 17 Nov 2003 02:25:01
Message: <web.3fb876b21fb47b0ce237f84a0@news.povray.org>
Hello all,
Is it possible to create an object that sparkles without using radiosity?
Thank you.
Subject: Re: sparkling objects
Date: 17 Nov 2003 10:08:48
Message: <cjameshuff-295E79.10052917112003@netplex.aussie.org>
In article <web.3fb876b21fb47b0ce237f84a0@news.povray.org>,
Well, your question is a bit odd...radiosity isn't any help in creating
a "sparkle" effect. You need to be more clear about what you want,
though. For highlights on a polished surface, look at the specular
keyword. (And phong if you like, though specular is supposed to be more
accurate.)
For a lens flare effect, you need to look at one of the several include
files that have been created for this purpose. I suggest Chris Colefax's
Lens Effects or Nathan Kopp's NKFlare:
http://www.geocities.com/SiliconValley/Lakes/1434/#IncludeFiles
http://www.nathan.kopp.com/nkflare.htm
http://tag.povray.org/
Date: 17 Nov 2003 11:35:01
Message: <web.3fb8f873dd85df02c9c3748c0@news.povray.org>
incognito wrote:
>Hello all,
>Thank you.
Thanks for your reply.
I meant more like glitter. I am not trying to make it realistic necessarily.
I am not permitted to use anything outside of standard include files
though.
Hope this clarifies my message.
Date: 17 Nov 2003 15:13:34
Message: <cjameshuff-239B44.15101617112003@netplex.aussie.org>
In article <web.3fb8f873dd85df02c9c3748c0@news.povray.org>,
Ok, that's a little more difficult. One good way might be to use the
facets pattern in the normal. Or one thing I've done before with good
results, put actual glitter on the object...thousands of smooth
triangles with the normals set up to make them appear slightly bent. The
trace() function will be of help in placing the glitter pieces on the
object, and a mesh can make the memory consumption tolerable.
> though.
Not permitted? Why not?
Date: 17 Nov 2003 16:45:01
Message: <web.3fb9414ddd85df02de0713960@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fb8f873dd85df02c9c3748c0[at]news.povray.org>,
>> though.
Just a guess - maybe this person is creating a trace for a course.
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
Date: 17 Nov 2003 17:25:02
Message: <web.3fb94a0edd85df0270c0121a0@news.povray.org>
Oh, didn't realize it was complex. Will look into this as time permits.
Thanks very much.
>>> though.
Date: 18 Nov 2003 14:19:02
Message: <cjameshuff-2B1D2A.14154718112003@netplex.aussie.org>
In article <web.3fb94a0edd85df0270c0121a0@news.povray.org>,
> >>> necessarily.
Did you look at my first suggestion, the facets pattern? I wouldn't
describe it as complex...
Date: 18 Nov 2003 22:05:00
Message: <web.3fbadd0cdd85df026adf13290@news.povray.org>
>In article <web.3fb94a0edd85df0270c0121a0[at]news.povray.org>,
>> >>> necessarily.
No, haven't had time yet. Thanks. Will see if I have time to try it later...
