POV-Ray : Newsgroups : povray.newusers : making sky only Server Time
10 Apr 2026 01:47:30 EDT (-0400)
  making sky only (Message 1 to 5 of 5)
Subject: making sky only
Date: 16 Nov 2003 18:15:01
Message: <web.3fb804b41087588a204769940@news.povray.org>
I was wondering if it is possible to use skies.inc to create a trace using
only a single background? I just want a background of a sky only (no
earth/ground) but it looks like most of the examples have both a sky and
ground portion...
Thanks a lot.
Subject: Re: making sky only
Date: 17 Nov 2003 10:10:18
Message: <cjameshuff-86CC02.10065917112003@netplex.aussie.org>
In article <web.3fb804b41087588a204769940@news.povray.org>,
> ground portion...
Just remove the ground. Of course, this won't be very realistic, since
in the real world you do have a ground...probably better to just point
the camera up.
http://tag.povray.org/
Date: 19 Nov 2003 23:15:01
Message: <web.3fbc3f722872e5c597ba87970@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fb804b41087588a204769940[at]news.povray.org>,
>> ground portion...
>the camera up.
No, my intention is not for this trace to be 100% realistic.
I tried removing the ground, however, this seems possible only with the
pigments.
I would like to use S_Cloud2 sky sphere since all the others are rather dark
for the effect I want but not sure how I can just use the top or bottom
half of it (would prefer to use the bottom half) (?)
Would appreciate any suggestions to do this.
Thank you for your help.
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
Date: 20 Nov 2003 03:19:32
Message: <3fbc7914$1@news.povray.org>
OK I got it,
The pigment used by S_Cloud2 is a gradient y one: value increases from  0 at
y=0 to 1 at y=1 ( assuming it is not scaled) then falls to 0 at y>1
increasing again to 1 at y=2 and so on
the value describes a sawtooth patern as you can see on this image
http://users.skynet.be/bs936509/povfr/materiaux/mat-mot-geo-01.htm
so value is 1 at y <0.
It is a new behaviour of gradient in POV 3.5
try using planar instead
#declare S_Cloud2 =
sky_sphere {
    pigment {planar
        pigment_map {
            [0.00 rgb <0.847, 0.749, 0.847> ] // horizon
            [0.10 SkyBlue ]                   // horizon
            [0.20 P_Cloud4 ]
HTH
Marc
Date: 23 Nov 2003 04:45:01
Message: <web.3fc081832872e5c5d31a135c0@news.povray.org>
Marc Jacquier wrote:
>OK I got it,
>#declare S_Cloud2 =
>sky_sphere {
>    pigment {planar
>        pigment_map {
>            [0.20 P_Cloud4 ]
Yes, this helps. Thanks for the tip.
>HTH
>Marc
