POV-Ray : Newsgroups : povray.newusers : Making grass Server Time
22 Dec 2025 15:50:59 EST (-0500)
  Making grass (Message 1 to 3 of 3)
Subject: Making grass
Date: 16 Nov 2003 00:15:03
Message: <web.3fb706a87f775ccbb26501b0@news.povray.org>
I've written a fairly simple grass macro. I want to use it to coat some
isosurface terrain. Each blade of grass consists of only 3 triangle
objects. The macro works by using trace() at a random x,z position with
each blade of grass. I think I need around 500,000 blades of grass to get a
realistic look. The problem here is that even with 2.1 Ghz and 1 GB of Ram,
I never even get to the rendering step of generating the output image. It
spends about a half hour on the parsing, and then at least 2 more hours on
generating bounding slabs (I quit after that).
I've seen some pictures with some very complicated-looking vegetation, so I
know this can be done. But I'm obviously doing something wrong.
Subject: Re: Making grass
Date: 16 Nov 2003 04:32:02
Message: <9rrj81-u12.ln1@triton.imagico.de>
3*500000 triangles should not be a problem if they are in one mesh
(500000 meshes with each 3 triangles could be a problems though).
None the less most scenes with complex vegetation make use of
instancing, i.e. the same mesh is used several times in the scene.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 16 Nov 2003 19:31:52
Message: <cjameshuff-D9A0DD.19283016112003@netplex.aussie.org>
In article <web.3fb706a87f775ccbb26501b0@news.povray.org>,
It sounds like you are constructing your grass out of individual
triangle objects. This is a very inefficient way to do it. Mesh objects
are designed for efficient storage of multiple triangles. For example,
your 3 triangle blades probably have 5 vertices. Doing it with 3
triangles requires storing 9 vertices, a mesh will store only 5.
Also, a copy of a mesh references the original data, rather than
creating a new copy. The usual way of making grass is to make several
mesh patches, and place many copies of these patches across the
landscape. This allows you to get good coverage with surprisingly little
memory usage.
http://tag.povray.org/
