![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.3fac0a66c881e4ced888c9910@news.povray.org>,
"pal### [at] yahoo com" <nomail@nomail> wrote:
> http://graphics.stanford.edu/~henrik/papers/smoke/
> That is html that explain exactly what I want!
This is a computational fluid dynamics simulation...to my knowledge,
nobody has done one with the ability to output to POV-Ray. Graphics
packages usually use particle systems for this sort of thing, which can
give convincing results, though not as accurate as this algorithm. There
are particle systems which include object interaction, your best bet is
to try one of those.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
pal### [at] yahoo com <nomail@nomail> wrote:
> Maybee mine english is not good enough but Lightflow can do this effect.
> Right now I found some sample and rendering it (in Lightflow).
Are you sure the sample scene is making flow calculations to get the
effect or just faking the effect with clever placement of objects?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you have some idea please tell me: in the other hand I will try to
produce this effect with huge number od particles.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
