POV-Ray : Newsgroups : povray.newusers : SCALING HEIGHT FIELD, GETTING RAY INTERSECTIONS OUT OF POV-RAY Server Time
21 Nov 2025 05:18:59 EST (-0500)
  SCALING HEIGHT FIELD, GETTING RAY INTERSECTIONS OUT OF POV-RAY (Message 1 to 2 of 2)
Subject: SCALING HEIGHT FIELD, GETTING RAY INTERSECTIONS OUT OF POV-RAY
Date: 3 Sep 2003 15:35:03
Message: <web.3f5641e0fd79e95a78c628a10@news.povray.org>
i have been using the pov-ray for modeling remote sensing images, So I have
some questions that i could not find an answer in pov-ray help:
    1.I'm using a PNG file as a height field (DIGITAL TERIAN MODEL - DTM),
this height field is imported to pov-ray to be in size of 1,1,1, I would
like to translate and         rescale the height field back to it's real
size and location. Are the pixels centers placed on the corners or are they
shifted 0.5 pixel inside form each direction ? (Should I use a factor for
translation of :  dx = x0 - 0.5*grid_dx ?). is the image map (png file)
scaling concept similar also to height field scaling and translation
concept?
 2. I'm defining the camera according to right_length vector, I know that
the pixel size in the camera plan is X (1.5 micro m), how to define the
length of right vector: X * columns  or X * (columns -1), generally speaking
how pov ray calculate the ray vector for intersection when using the trace
function ?
 3. How can I get out of pov ray X,Y,Z of the intersections ? I have added
also building to scene (group of poly)
Subject: Re: SCALING HEIGHT FIELD, GETTING RAY INTERSECTIONS OUT OF POV-RAY
Date: 4 Sep 2003 13:29:50
Message: <cjameshuff-67955B.13294704092003@netplex.aussie.org>
In article <web.3f5641e0fd79e95a78c628a10@news.povray.org>,
> size and location.
The "real" size and location is whatever you need it to be. POV
coordinates have no relation to real-world units, and certainly no
relation to coordinates on a globe.
> concept?
I really have no idea what you're asking here...but it sounds like you
really don't understand how image maps and height fields work. I suggest
you go back and read the documentation, maybe look at the earlier
threads in these groups.
> function ?
Again, I have no idea what you're asking. You may be going at it the
wrong way, try describing exactly what you're attempting to do rather
than assuming it must be done a certain way.
Look up the trace() function.
http://tag.povray.org/
