POV-Ray : Newsgroups : povray.newusers : Halo effect through clouds Server Time
22 Dec 2025 19:28:25 EST (-0500)
  Halo effect through clouds (Message 1 to 10 of 12)
Subject: Halo effect through clouds
Date: 24 Jul 2003 14:50:01
Message: <web.3f202a007a7870359478e7c60@news.povray.org>
  Does anyone know how to achieve this "halo" effect of a star being seen
behind a cloud and, I assume because of scattering, there is a bright ring
around the star?  I have made the cloud a media object with scattering, but
I can't seem to get a nice "halo" around the star/light source.
Thanks for any suggestions.
Subject: Re: Halo effect through clouds
Date: 24 Jul 2003 16:10:26
Message: <3f203d32@news.povray.org>
http://geocities.com/ccolefax/lenseffects.html
Date: 24 Jul 2003 19:10:01
Message: <web.3f2066e8ce8953889478e7c60@news.povray.org>
Nice...thanks a lot.
Just wondering, is there no "natural" way of getting these effects, like
from scattering of the light or photons in POVray?
Date: 24 Jul 2003 19:18:47
Message: <3f206957@news.povray.org>
Some have tried, many have failed. The amount
of photons and the tracing depth for a sufficient
effect are just... well... high.
Tim Nikias v2.0
x]
Warp -
Version: 6.0.502 / Virus Database: 300 - Release Date: 18.07.2003
Date: 24 Jul 2003 20:45:45
Message: <cjameshuff-ADEC5E.19454824072003@netplex.aussie.org>
In article <3f203d32@news.povray.org>, Warp <war### [at] tagpovrayorg>
What Penners is looking for is actually produced by atmospheric
scattering, not a lens effect. Unfortunately, the scattering models used
in POV peak at an angle of 0 to the light, so you get a glow that's
brightest around the source and just falls off from there. The ice
crystals that cause this effect scatter light differently, peaking at 22
degrees. POV just doesn't have a scattering model that describes this
effect. Maybe the scattering intensity curve could be specified with a
user-defined function, this would give a great deal more flexibility.
http://tag.povray.org/
Date: 24 Jul 2003 20:56:11
Message: <cjameshuff-E27C1B.19561224072003@netplex.aussie.org>
In article <cja### [at] netplexaussieorg>,
Here's some good pictures of the effect:
http://antwrp.gsfc.nasa.gov/apod/ap000515.html
http://antwrp.gsfc.nasa.gov/apod/ap020114.html
http://antwrp.gsfc.nasa.gov/apod/ap030321.html
Date: 25 Jul 2003 02:19:17
Message: <3f20cbe5@news.povray.org>
Penners <pen### [at] hotmailcom> wrote in message
news:web.3f202a007a7870359478e7c60@news.povray.org...
> Hi,
but
I think you can do that using a hollow sphere filled with scattering media
using a spherical color map with the middle transparent so color only  shows
around the outside.
This isn't the same thing;
http://www.irtc.org/ftp/pub/stills/2003-06-30/lites_rg.jpg,
but while I was experimenting with the media for it I got something like
what you want.  The code is here;
http://www.irtc.org/ftp/pub/stills/2003-06-30/lites_rg.zip
Look at the color map I used and play with it. You can either put it around
the star, or between the star and the clouds.  Play with the placement, but
I think it should work.
RG
Date: 25 Jul 2003 08:31:01
Message: <3f212305@news.povray.org>
  If you can use a fake which renders in 1 second and which looks as
good as the real thing... why bother?
Date: 25 Jul 2003 08:47:57
Message: <3f2126fd$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3f212305@news.povray.org...
"Because" - moving to O.T.....
Date: 25 Jul 2003 13:35:01
Message: <web.3f216933ce8953885c46d5e30@news.povray.org>
Thanks everyone for all your help/suggestions.  I really appreciate it.
