Warp wrote:
>http://geocities.com/ccolefax/lenseffects.html
>#macro M(A,N,D,L)plane{-z,-9pigment{mandel L*9translate N color_map{[0rgb x]
>-1<.7438.1795>1,20)M(1<.77595.13699>30,20)M(3<.75923.07145>80,99)// - Warp -
Nice...thanks a lot.
Just wondering, is there no "natural" way of getting these effects, like
from scattering of the light or photons in POVray?
Some have tried, many have failed. The amount
of photons and the tracing depth for a sufficient
effect are just... well... high.
Tim Nikias v2.0
x]
Warp -
Version: 6.0.502 / Virus Database: 300 - Release Date: 18.07.2003
In article <3f203d32@news.povray.org>, Warp <war### [at] tagpovrayorg>
What Penners is looking for is actually produced by atmospheric
scattering, not a lens effect. Unfortunately, the scattering models used
in POV peak at an angle of 0 to the light, so you get a glow that's
brightest around the source and just falls off from there. The ice
crystals that cause this effect scatter light differently, peaking at 22
degrees. POV just doesn't have a scattering model that describes this
effect. Maybe the scattering intensity curve could be specified with a
user-defined function, this would give a great deal more flexibility.
Christopher James Huff <cja### [at] earthlinknet>
POV-Ray TAG: chr### [at] tagpovrayorg
http://tag.povray.org/
In article <cja### [at] netplexaussieorg>,
Here's some good pictures of the effect:
http://antwrp.gsfc.nasa.gov/apod/ap000515.html
http://antwrp.gsfc.nasa.gov/apod/ap020114.html
http://antwrp.gsfc.nasa.gov/apod/ap030321.html
Penners <pen### [at] hotmailcom> wrote in message
news:web.3f202a007a7870359478e7c60@news.povray.org...
> Hi,
> Does anyone know how to achieve this "halo" effect of a star being seen
> behind a cloud and, I assume because of scattering, there is a bright ring
> around the star? I have made the cloud a media object with scattering,
but
> I can't seem to get a nice "halo" around the star/light source.
> Thanks for any suggestions.
I think you can do that using a hollow sphere filled with scattering media
using a spherical color map with the middle transparent so color only shows
around the outside.
This isn't the same thing;
http://www.irtc.org/ftp/pub/stills/2003-06-30/lites_rg.jpg,
but while I was experimenting with the media for it I got something like
what you want. The code is here;
http://www.irtc.org/ftp/pub/stills/2003-06-30/lites_rg.zip
Look at the color map I used and play with it. You can either put it around
the star, or between the star and the clouds. Play with the placement, but
I think it should work.
RG
If you can use a fake which renders in 1 second and which looks as
good as the real thing... why bother?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
"Warp" <war### [at] tagpovrayorg> wrote in message news:3f212305@news.povray.org...
"Because" - moving to O.T.....
Thanks everyone for all your help/suggestions. I really appreciate it.
Christopher James Huff wrote:
>In article <3f203d32[at]news.povray.org>, Warp <war### [at] tagpovrayorg>
>http://home.earthlink.net/~cjameshuff/
This is exactly what I mean. Is there somewhere you could point me to
learn more about this scattering phenomenon and/or a scattering model that
defines it...out of curiosity.
Thanks!
Penners
In article <web.3f216b4dce8953885c46d5e30@news.povray.org>,
A simple Google search shows some possibilities:
http://www.google.com/search?q=scattering+ice+crystal+halo+22
