POV-Ray : Newsgroups : povray.newusers : (vector) sum of two objects Server Time
13 Mar 2026 02:24:50 EDT (-0400)
  (vector) sum of two objects (Message 21 to 30 of 52)
Subject: Re: (vector) sum of two objects
Date: 24 Apr 2003 09:22:05
Message: <MPG.1911f552ac74fc49896a3@news.povray.org>
Achill wrote:
> > Let's say we have a unit cube between <0,0,0> and <1,1,1> and a sphere at
> > <0,0,0> with radius 1.  What is the 'vector sum' of these objects?
> As far as I understand the macro
> "Round_Box_Union(PtA, PtB, EdgeRadius)",
> it would be "Round_Box_Union(<0,0,0>, <1,1,1>, 1)".
It would be Round_Box_Union(<-1,-1,-1>, <2,2,2>, 1), because the
Round_Box macros cut away from the specified box, rather than
adding to it.
Date: 24 Apr 2003 09:48:25
Message: <cjameshuff-0C4912.09481524042003@netplex.aussie.org>
In article <3EA### [at] matumde>, Achill <ach### [at] matumde>
wrote:
> I do not know of a concrete "practical usage" either. My main idea was
> to visualize the mathematical defintion of the vector sum (also known as
> Minkowski sum, see http://mathworld.wolfram.com/MinkowskiSum.html) of
> two arbitrary sets.
> Besides I think this would give some nice effects. For example a general
> "rounding" by adding a sphere.
I think you need to learn more about how raytracing works. POV can not
take the "vector sum of all points on an object", because it doesn't
know all points on the object. Raytracing works by finding the
intersection point of rays with surfaces, the various shape types use a
wide variety of methods to do this, ranging from simple geometric
formulas to complex root-finding algorithms. You can't just add these
intersection finding algorithms together to get a new one.
Your idea seems to depend on having two sets of points and resulting in
a third set, POV does not have the first two sets and wouldn't be able
to do anything with the third (though there is a method for raytracing
point fields that might be useful with this, it is not currently
implemented in POV).
Yes, a general rounding algorithm would be nice sometimes, but it is not
possible without completely changing the way POV handles shapes. If it
is ever added to POV, it will probably be a mesh processing feature.
http://tag.povray.org/
Date: 24 Apr 2003 09:50:54
Message: <3EA7EBA5.5000601@ma.tum.de>
> adding to it.
So I did not understand the macro too far... :-)
Should have tried before mailing...
Achill
Date: 24 Apr 2003 09:53:47
Message: <cjameshuff-EFB98A.09533124042003@netplex.aussie.org>
The vector sum of a sphere and a box is 3 boxes, 8 spheres, and 12
cylinders?
Date: 24 Apr 2003 10:06:14
Message: <3EA7EF3C.5000008@ma.tum.de>
> cylinders?
Its the union of them, yes.
That is a consequence of the so called "Steiner Theorem" in "convex
geometry".
Achill
Date: 24 Apr 2003 10:11:57
Message: <3EA7F092.4010402@ma.tum.de>
That is certainly true --- as it is with most things... :-)
(That's why I am posting to "newusers".)
> POV can not
I saw on http://www.f-lohmueller.de/pov_tut/csg/povcsg1e.htm that CSG
operations may be used with all shapes which have a clear defined
"inside" and "outside", in particular with solids. My idea was that it
should be possible to determine "inside" and "outside" of the sum (at
least for the sum of solids) as well...?!?
I must admit, I do not know how povray "knows" to distiguish "inside"
and "outside".
I see that I will have to learn much more about povray and raytracing in
general... :-)
Achill
Date: 24 Apr 2003 10:18:51
Message: <4dsfavsgv7emj49rr7irlfv9j7cfvf6mkr@4ax.com>
> and "outside".
It's hardcoded definition of each primitive object. Like math representation of
its surface, function to calculate normal vectors, mapping uv space on its
surface etc.
ABX
Date: 24 Apr 2003 11:51:22
Message: <cjameshuff-9DB8F5.11510924042003@netplex.aussie.org>
> geometry".
And how do you compute a union of primitives equivalent to a given "sum"
of objects? Your reasoning process seems to have been "it will make a
rounded box, and here's a rounded box macro".
Date: 24 Apr 2003 11:54:27
Message: <cjameshuff-C4BC2A.11541624042003@netplex.aussie.org>
> and "outside".
It can check whether a given point is inside or outside the object,
using a hard-coded object-specific algorithm. How does that help? It
doesn't get you any closer to summing objects.
Date: 24 Apr 2003 12:05:03
Message: <h32gavo8csv7vcgefdsi0fl3ei8orr0cdq@4ax.com>
On Thu, 24 Apr 2003 11:51:09 -0400, Christopher James Huff
That's me who suggested that macro. When I refered to it I wasn't sure if he is
interested in METHOD or RESULT of his description. Since there was no way to
duplicate METHOD in universal way I could only help with referring tool where
similiar RESULT he described was achived. As to the newuser who come here to
achive something I showed him shortest way to achive RESULT he described in
example. I thought it could save him learning of full POV SDL power.
I'm still not sure if he is rather interested in RESULT of specific case of his
sum or in general METHOD. I hope my hints helped him and I hope you are not
angry that I answered instead of licensed TAG member ;-)
ABX
