POV-Ray : Newsgroups : povray.newusers : Ok, what did I miss? Server Time
19 Sep 2025 00:02:07 EDT (-0400)
  Ok, what did I miss? (Message 1 to 2 of 2)
Subject: Ok, what did I miss?
Date: 13 Nov 2002 22:30:04
Message: <web.3dd3174d14254fc19af8ec6b0@news.povray.org>
I made a simple texture, roughed it up a little bit with "crand", which
looked like I wanted except (as noted in the docs) it doesn't change with
distance. The docs also say crand is obsolete and to use noise_generator
instead, specifically mentioning that it gets rid of this problem.
So, how do I do that? Noise_generator only accepts 1 parameter, which only
selects which generator to use. How do I get it to give me a nice rough
texture like crand? So far it accepts the command without error, so I assume
I'm not making any glaring mistakes, but nothing changes in my texture at
all.
Thanks.
Subject: Re: Ok, what did I miss?
Date: 13 Nov 2002 22:52:20
Message: <chrishuff-35B908.22514213112002@netplex.aussie.org>
In article <web.3dd3174d14254fc19af8ec6b0@news.povray.org>,
> all.
Well, I don't know what that part of the documentation was supposed to
mean...sounds odd to me. However, if you want a rough looking surface,
try using a granite normal scaled very small. A wrinkles normal could
also work well.
http://tag.povray.org/
