POV-Ray : Newsgroups : povray.newusers : Cube in different colors ? Server Time
5 Apr 2026 07:24:37 EDT (-0400)
  Cube in different colors ? (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Cube in different colors ?
Date: 10 Sep 2002 21:43:06
Message: <3D7EA09E.DEC45C3E@pacbell.net>
Christopher James Huff wrote:
> I don't know if you meant this, but that last paragraph implies that a
> mesh box would be unuseable in CSG. If he uses inside_vector, it will be
> useable for CSG operations.
Works quite well actually :)
// Macro for creating a basic box object using triangles
#macro Box_Mesh(Vec1,Vec2)
#if (Vec1.x=Vec2.x | Vec1.y=Vec2.y | Vec1.z=Vec2.z)
#debug "\n  MeshBox detected identical vector values.\n" #end
#local P1=<Vec1.x, Vec1.y, Vec1.z>;
#local P2=<Vec2.x, Vec1.y, Vec1.z>;
#local P3=<Vec2.x, Vec1.y, Vec2.z>;
#local P4=<Vec1.x, Vec1.y, Vec2.z>;
#local P5=<Vec1.x, Vec2.y, Vec1.z>;
#local P6=<Vec2.x, Vec2.y, Vec1.z>;
#local P7=<Vec2.x, Vec2.y, Vec2.z>;
#local P8=<Vec1.x, Vec2.y, Vec2.z>;
mesh {
       triangle { P5, P1, P2 texture {T1} }
       triangle { P5, P6, P2 texture {T1} }
       triangle { P6, P2, P3 texture {T2} }
       triangle { P6, P7, P3 texture {T2} }
       triangle { P7, P3, P4 texture {T3} }
       triangle { P7, P8, P4 texture {T3} }
       triangle { P8, P4, P1 texture {T4} }
       triangle { P8, P5, P1 texture {T4} }
       triangle { P8, P5, P6 texture {T5} }
       triangle { P8, P7, P6 texture {T5} }
       triangle { P4, P1, P2 texture {T6} }
       triangle { P4, P3, P2 texture {T6} }
       inside_vector <0, 0, 1>
default { finish { ambient .4 diffuse .6 } }
#declare T1 = texture { pigment { rgb<1,0,0> }}
#declare T2 = texture { pigment { rgb<0,1,0> }}
#declare T3 = texture { pigment { rgb<0,0,1> }}
#declare T4 = texture { pigment { rgb<1,1,0> }}
#declare T5 = texture { pigment { rgb<1,0,1> }}
#declare T6 = texture { pigment { rgb<0,1,1> }}
// Usage
camera{location<-4,4,-4> look_at 0}
light_source{<-5,5,-5>rgb 1}
difference
  Box_Mesh ( <-1,-1,-1>, <1,1,1> )
  cylinder { z*-1.1, z*1.1, .75 pigment { rgb 1 }}
Ken Tyler
Date: 10 Sep 2002 23:37:37
Message: <3D7EBB75.342E8017@pacbell.net>
With limitations. From some tests I just ran it appears the mesh must be
the top level object in the csg operation. If used a secondary object
in a csg it does not work as expected. I wonder if an outside_vector
operator is needed to define the outside of a mesh object as opposed
to the inside?
Ken Tyler
Date: 11 Sep 2002 00:08:19
Message: <Xns92863DC0CA432raf256com@204.213.191.226>
"gam### [at] gmxnet" <gam### [at] gmxnet> wrote in
news:web.3d7e1dbe52cba467df9f5c610@news.povray.org
> Hi! I am new with povray and wanted to render a box where the 6 sides
> are in different colors. Is there a way to manipulate the box object,
> or do i have to draw the 6 sides as 6 single boxes (CSG). Maybe
> UVmapping ?
hmm interesting, I was just about to send identical question here...
maybe telepatic ;) ?
so finaly - with method is the fastest ?
maybe some union/merge/intersection of planes ?
Date: 11 Sep 2002 05:42:41
Message: <3d7f1011@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
> My feeling is that this would be the fastest way. You may have to tell
> POV not to ignore your bounding, though.
  I think that POV-Ray only removes user-defined bounding boxes when it
(thinks it) can make a better one itself. However, for planes it doesn't
create bounding boxes at all (because they are infinite) and thus should
not remove the user-defined one. I haven't tried it, though.
  Well, yes. That's what I meant (could have worded it better, though).
  A mesh by itself is not usable in CSG, but if you add inside_vector to
it, then it is.
Date: 11 Sep 2002 05:44:12
Message: <3d7f106b@news.povray.org>
  I remember that this bug was found months ago. I wonder if anyone made
a proper post at p.bug-reports... (if not, someone should).
Date: 11 Sep 2002 05:58:58
Message: <8k4unuk183qmnfaropqo2aql15vu989oai@4ax.com>
> to the inside?
I wonder if it could be becouse of feature described recently in some posts.
All_intersections method for meshes returns only first intersection. I don't
know how intersection test for csg is written but for sended ray mesh looks
like plane so it can behave strange in some cases.
ABX
Date: 11 Sep 2002 07:50:32
Message: <3d7f2e08@news.povray.org>
  I made a test with boxes made of planes, polygons and a mesh (with
differently colored sides) and compared their rendering speed
(-w800 -h600 +a0.1) by randomly placing 500 of them in the scene.
The render times were:
Planes:   75 s
Polygons: 80 s
Mesh:     63 s
  Seems like the mesh wins.
  This is the scene:
// 1: Planes
// 2: Polygons
// 3: Mesh
#declare BoxType = 1;
#declare Amount = 500;
#macro FixCorners(Corner1, Corner2)
  #local X1 = Corner1.x; #local X2 = Corner2.x;
  #local Y1 = Corner1.y; #local Y2 = Corner2.y;
  #local Z1 = Corner1.z; #local Z2 = Corner2.z;
  #if(X1 > X2) #local tmp = X1; #local X1 = X2; #local X2 = tmp; #end
  #if(Y1 > Y2) #local tmp = Y1; #local Y1 = Y2; #local Y2 = tmp; #end
  #if(Z1 > Z2) #local tmp = Z1; #local Z1 = Z2; #local Z2 = tmp; #end
  #local Corner1 = <X1, Y1, Z1>;
  #local Corner2 = <X2, Y2, Z2>;
#macro PlaneBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  #local C1 = Corner1+<0,0,0>;
  #local C2 = Corner2+<0,0,0>;
  FixCorners(C1, C2)
  intersection
    plane { -x, -C1.x texture { T1 } }
    plane {  x,  C2.x texture { T2 } }
    plane { -y, -C1.y texture { T3 } }
    plane {  y,  C2.y texture { T4 } }
    plane { -z, -C1.z texture { T5 } }
    plane {  z,  C2.z texture { T6 } }
    bounded_by { box { C1, C2 } }
#macro PolygonBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  FixCorners(C1, C2)
  union
    polygon
    { 5, C1, <C1.x, C1.y, C2.z>, <C1.x, C2.y, C2.z>, <C1.x, C2.y, C1.z>, C1
      texture { T1 }
    polygon
    { 5, C2, <C2.x, C2.y, C1.z>, <C2.x, C1.y, C1.z>, <C2.x, C1.y, C2.z>, C2
      texture { T2 }
    polygon
    { 5, C1, <C2.x, C1.y, C1.z>, <C2.x, C1.y, C2.z>, <C1.x, C1.y, C2.z>, C1
      texture { T3 }
    polygon
    { 5, C2, <C1.x, C2.y, C2.z>, <C1.x, C2.x, C1.z>, <C2.x, C2.y, C1.z>, C2
      texture { T4 }
    polygon
    { 5, C1, <C2.x, C1.y, C1.z>, <C2.x, C2.y, C1.z>, <C1.x, C2.y, C1.z>, C1
      texture { T5 }
    polygon
    { 5, C2, <C1.x, C2.y, C2.z>, <C1.x, C1.y, C2.z>, <C2.x, C1.y, C2.z>, C2
      texture { T6 }
#macro MeshBox(Corner1, Corner2, T1, T2, T3, T4, T5, T6)
  FixCorners(C1, C2)
  mesh2
    vertex_vectors
    { 8,
      <C1.x, C2.x, C1.z>, <C2.x, C2.y, C1.z>, C2, <C1.x, C2.y, C2.z>
    texture_list
    { 6,
      texture { T1 }, texture { T2 }, texture { T3 },
      texture { T4 }, texture { T5 }, texture { T6 }
    face_indices
    { 6*2,
      <0, 3, 7>, 0, <0, 7, 4>, 0,
      <1, 5, 6>, 1, <1, 6, 2>, 1,
      <0, 1, 2>, 2, <0, 2, 3>, 2,
      <4, 7, 6>, 3, <4, 6, 5>, 3,
      <0, 4, 5>, 4, <0, 5, 1>, 4,
      <3, 2, 6>, 5, <3, 6, 7>, 5
camera { location <4,10,-20>*2 look_at 0 angle 35 }
light_source { <100,200,-150>, 1 }
#declare T = array[6]
  pigment { rgb 1 },
  pigment { rgb x },
  pigment { rgb y },
  pigment { rgb z },
  pigment { rgb x+y },
  pigment { rgb y+z },
#declare Box =
  #switch(BoxType)
    #case(1)
      PlaneBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
    #case(2)
      PolygonBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
    #case(3)
      MeshBox(-1, 1, T[0], T[1], T[2], T[3], T[4], T[5])
    #break
#declare S = seed(1);
#declare Ind = 0;
#while(Ind < Amount)
  object
  { Box
    rotate <rand(S)*360, rand(S)*360, rand(S)*360>
    translate (<rand(S),.5,rand(S)>-.5)*50
  #declare Ind = Ind+1;
Date: 11 Sep 2002 08:17:45
Message: <3tcunucfmpi3no5lndl78ghqn4tvt6t8pl@4ax.com>
On 11 Sep 2002 07:50:32 -0400, Warp <war### [at] tagpovrayorg> wrote:
> Planes:   75 s
> Polygons: 80 s
> Mesh:     63 s
since the uvmapped box was counted as possible solution for the question in
subject where is the time for boxes :-)
ABX
Date: 11 Sep 2002 08:23:29
Message: <3D7F36B6.2BB355A0@pacbell.net>
I only vaugly remember this topic and don't recall if it was ever confirmed
and reported. If confirmed I would be willing to file a formal bug report.
Ken Tyler
Date: 11 Sep 2002 09:43:04
Message: <chrishuff-C7E2A7.09424011092002@netplex.aussie.org>
In article <3d7f2e08@news.povray.org>, Warp <war### [at] tagpovrayorg>
> Planes:   75 s
> Polygons: 80 s
> Mesh:     63 s
Hmm, not what I expected. I would have thought that finding an
intersection against 12 planes and clipping them to triangles would be
slower than intersecting 6 planes...maybe the mesh bounding is making
more of a difference than I thought, or maybe intersection has more
overhead than I thought.
Hmm, maybe a union of 6 clipped planes would be faster. Bound each plane
individually, so POV can eliminate the faces...
http://tag.povray.org/
