POV-Ray : Newsgroups : povray.newusers : Heighfields -are they meshes or 'just' textures? Server Time
10 Apr 2026 16:08:06 EDT (-0400)
  Heighfields -are they meshes or 'just' textures? (Message 1 to 10 of 11)
Subject: Heighfields -are they meshes or 'just' textures?
Date: 14 Aug 2002 07:15:06
Message: <web.3d5a39c91ed38c652f4bd1e30@news.povray.org>
Hello all!
I'm Completely new and have been working through the tutorial and made all
the examples. I'm very interested in the Heighfields. I would so like to
use the outputs in a 3d engine as 'worlds'.
I have read the section of 'export to other formats' and it is stated there
that a special pov by Thomas Baier (POB) can export MESH obj to other
formats
Now is it want to know:
Is heightfields real meshes that can be "exported" to 3ds or .x using this
utility?
Is so.. Where can I get the utility (dead link)
regards Krus
Subject: Re: Heighfields -are they meshes or 'just' textures?
Date: 14 Aug 2002 07:56:03
Message: <3d5a4553@news.povray.org>
"krus" <nomail@nomail> schrieb im Newsbeitrag
news:web.3d5a39c91ed38c652f4bd1e30@news.povray.org...
> utility?
I'm no expert in this field, but IIRC the heightfield-primitive is
internally represented as a mesh. I don't know if this means that the
special POV can output that though.
But - there is no need for this. Have a look at the HF_Square-macro in
shapes.inc the standard distribution of V 3.5. It will build a mesh from a
user-defined function and may write it to a file. You still will have to
convert that output as it's unlikely that some other program supports
POV-meshes directly - but that shouldn't be too hard, if you know the
description of the format you want to use.
I hope that helps,
Marc-Hendrik
Date: 14 Aug 2002 08:05:21
Message: <3d5a4781$1@news.povray.org>
"krus" <nomail@nomail> wrote in message
<snip>
Hmm, a height field takes, as its input, an image.
Are you sure that program x can't do the same? Certainly Leveller (a hf
manipulation program) can do this and then let you edit the terrain and export
to other formats.
Date: 14 Aug 2002 09:05:05
Message: <web.3d5a53a1e9a1db2d2f4bd1e30@news.povray.org>
Marc-Hendrik Bremer wrote:
>"krus" <nomail[at]nomail> schrieb im Newsbeitrag
>news:web.3d5a39c91ed38c652f4bd1e30[at]news.povray.org...
>> utility?
>I hope that helps,
>Marc-Hendrik
>>Marc thats sound VERY interesting! -But i'm not sure if i understand *s*
Certently i do NOT understand the 'function' keyword in the macro.
This is what i got:
// macros for generating various shapes
#include "shapes.inc"
  #include "skies.inc"
//uses output af heightImage som heightImage.bmp
  camera{
    location <0, 2, -10>
her udelades meget af forgrunden
    angle 0
  light_source{ <10000,10000,-1000000> Red }
  light_source{ <-1000,1000,-10000> Yellow }
  light_source{ <-100,100,-100> White }
height_field {
    //sys "heightImage.bmp"
    sys "textAdv.bmp"
    smooth
    pigment {White }
    translate <-.5, -.5, -.5>
    scale <17, 1.975, 17>
  #macro
//HF_Square
//(Function, UseUVheight, UseUVtexture, Res, Smooth, FileName, MnExt,
MxExt).
     HF_Square (????, false, false, <1,1>, false, "myMapMesh", 100, 100).
  sky_sphere { S_Cloud4 }
//code end
could you show me what 'Function' could/should be. I've tried whith
x=1, 1*x, 0, x^1, ..all because i do not want the image to change
I get a parse-error with all the abowe
....also the four '????' do not work ;)
Thanks!! for that fast reply Both of you!
regards krus
Date: 14 Aug 2002 09:05:07
Message: <web.3d5a5572e9a1db2d2f4bd1e30@news.povray.org>
Tom Melly wrote:
>"krus" <nomail[at]nomail> wrote in message
><snip>
>to other formats.
>> Hi Tom
As u can see in the abowe code i am using a .bmp as the source for the HF. I
believe the u with 'program x' is referring to the program i want to use
the mesh in, but that program need a 3ds or .x file.
I do not know Leveller, But i hope the macro solution will solve my problem
Thanks for ur reply!
regard krus
Date: 14 Aug 2002 09:21:37
Message: <3d5a5961$1@news.povray.org>
news:web.3d5a5572e9a1db2d2f4bd1e30@news.povray.org...
> regard krus
No problem - take a look at
http://www.daylongraphics.com/products/leveller/tour/index.htm
for a list of export options from leveller
Date: 14 Aug 2002 11:10:59
Message: <3d5a7302@news.povray.org>
  It is internally a mesh, but the same kind of mesh which mesh/mesh2 creates.
Is an optimized one.
Date: 14 Aug 2002 12:52:44
Message: <chrishuff-4F0BA7.11410914082002@netplex.aussie.org>
In article <web.3d5a53a1e9a1db2d2f4bd1e30@news.povray.org>,
> This is what i got:
Hmm, that's...not even close. Never used macros before?
You don't need the #macro...#end in the macro call, they are only used
to define the macro. And you aren't supposed to use it in a
height_field, the macro generates a new mesh primitive.
These macros are well documented in the manual, and there are examples
in scenes/incdemo/shapes.pov. You would use something like:
#declare HF_Fn =
function {
        image_map {sys "textAdv.bmp" interpolate 2}
        rotate x*90
object {
    HF_Square(function {HF_Fn(x, y, z).gray}, false, false, <100, 100>,
true, "myMapMesh", < 0, 0, 0>, < 1, 1, 1>)
    pigment {White}
HF_Fn is a pigment function, it gives the color of a pigment at a point.
The ".gray" in the function given to the macro turns it into a float
value useable as a height. The rotation by x*90 is necessary because the
image_map is in the xy plane and you need it in the xz plane.
You specified a mesh resolution of 1*1, which obviously won't work...I
used 100*100, you should use something close to the size of your image
file, though you could reduce it for lower-quality meshes. You specified
"smooth" in your height field, so I assumed you wanted a smooth height
field from the macro and set that option to true. And specifying "100"
for both corners of the box containing the height field won't work, I
specified < 0, 0, 0> and < 1, 1, 1>, like the built-in height_field
shape.
And note that "myMapMesh" won't be affected by the texture and
translations you do to the object. You could adjust the pigment given to
HF_Fn and the size given to the height field macro to generate a height
field of the desired size instead, for texturing you would have to
manually edit the generated file, but I think the conversion program
will ignore it anyway.
http://tag.povray.org/
Date: 15 Aug 2002 05:25:04
Message: <web.3d5b72eee9a1db2d2f4bd1e30@news.povray.org>
Christopher James Huff wrote:
>In article <web.3d5a53a1e9a1db2d2f4bd1e30[at]news.povray.org>,
>> This is what i got:
>#declare HF_Fn =
>function {
>    pigment {
>        rotate x*90
>object {
>    pigment {White}
>shape.
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
THANK YOU! not only for the valuable and detailed help but especially for
the hint to the examples in shapes.pov!
Still there's one problem with the code.
I do get a normal picture if i omit the filename eg:
true, "", < 0, 0, 0>, < 1, 1, 1>)
But if i ad a file:
-I get a parse-error:
" expected 'object' translate found instead"
-on the other hand, a file IS made and written to hd and i have opened it
and it seams to contain the correct information:
mesh2
 vertex_vectors 10000,{....}//{..some thousend vectors..}
  normal_vectors 10000, {....}
 face_indices 19602, {....}
I do have a problem with that file though -What is the file-type (eg
extension) for this file (believe it to be a mesh2-file? a .wrl-file?)
I fear that converting does something wrong with the file because the output
3ds-file is only 1 kb and contain no information at all.
I would greatly apreciate any help
regards krus
Date: 15 Aug 2002 07:06:35
Message: <3d5b8b3b@news.povray.org>
news:web.3d5b72eee9a1db2d2f4bd1e30@news.povray.org...
> But if i ad a file:
That's because no object is defined. The mesh is written to the file but not
build in memory. To use it you have to include it, like
object{#include"myMapMesh" translate ...}.
It's pov-script, as if you would build the mesh by hand. I don't know if
converters exist allready, but as it's all text, it should be possible to
convert it.
Marc-Hendrik
