POV-Ray : Newsgroups : povray.newusers : uv_mapping with the checkers pattern Server Time
17 Jan 2026 01:02:48 EST (-0500)
  uv_mapping with the checkers pattern (Message 1 to 4 of 4)
Subject: uv_mapping with the checkers pattern
Date: 19 Oct 2005 10:21:57
Message: <uhlcl1hibge063hsicsorm31l42u7kt96e@4ax.com>
I'm trying to move a sphere in an animation, and I notice that the
checkers pattern doesn't "stick" to the sphere.
I tried using uv_mapping but then only the first color of the checker
is used as the pigment of the sphere.
How do I move a sphere and make the initial checkers pattern "stick"
to it?
Subject: Re: uv_mapping with the checkers pattern
Date: 19 Oct 2005 10:52:22
Message: <3iCO3BAg2lVDFwKs@econym.demon.co.uk>
>to it?
  texture {uv_mapping pigment {checker} scale <0.1, 0.147> }
With uv_mapping, the part of the texture that would normally cover the
square from <0,0> to <1,1> is mapped to the whole surface, even if the
sphere is much larger than that. But for the checker pattern, each of
the coloured checkers is a 1x1 square, so to see any pattern you need to
scale down.
[Because the pattern is in uv-space instead of xyz-space, only the first
two dimensions of scaling are meaningful.]
Mike Williams
Gentleman of Leisure
Date: 19 Oct 2005 11:10:46
Message: <435661f6@news.povray.org>
> to it?
I think your problem lies less with the uv-mapping, but more with where you
apply the transformation to the sphere. Is it after the texture is applied,
or before?
If you apply the transformations before the texture, the texture doesn't
transform/move with the sphere, if it is applied after the texture, the
texture gets transformed as well.
Tim
"Tim Nikias v2.0"
Date: 22 Oct 2005 18:04:05
Message: <9pdll11268j4jcphe66jp9ubl4rdojod1n@4ax.com>
That did it, thank you
On Wed, 19 Oct 2005 15:52:16 +0100, Mike Williams
>>to it?
>scale down.
