POV-Ray : Newsgroups : povray.newusers : desert sand Server Time
20 Aug 2025 11:32:32 EDT (-0400)
  desert sand (Message 1 to 4 of 4)
Subject: desert sand
Date: 19 Oct 2004 01:19:10
Message: <pan.2004.10.19.05.19.06.431620@localhost.localdomain>
Hi all, I am trying to create a desert plain, and have been experimenting
with isosurface. I have this:
  isosurface {
    function { y+f_noise3d(x,0, z)*0.25 }
    threshold 1
    contained_by { box { -20, 20 } }
    pigment { Wheat }
    normal { bumps 0.3 scale 0.1 }
but it appears to be out of focus up close to the camera...  Any other
ideas on how to achieve a desert plain.
By plain I dont mean a totaly flat plain, but with gentle dunes etc...
Subject: Re: desert sand
Date: 19 Oct 2004 03:15:33
Message: <C9icxKAD8LdBFwk8@econym.demon.co.uk>
>  isosurface {
>    threshold 1
>    pigment { Wheat }
You may find that it looks a little better if you don't mix real
isosurface bumpiness with fake normal bumps. Since bumps and f_noise3d
use the same noise engine, you can convert your normal into part of the
isosurface, like this.
  isosurface {
    function { y
     +f_noise3d(x*10,0,z*10)*0.03
    threshold 1
    pigment { Wheat }
Or, for a little more sharpness, try this:
  isosurface {
    function { y
     +pow(f_noise3d(x*10,y*10,z*10),2)*0.02
    threshold 1
    pigment { Wheat }
Or, for a lot more sharpness, and you don't mind it running a bit
slower, add some fine structure like this. (If you change the settings
of the P function you may well need to adjust the max_gradient).
#declare P=function{
 pigment{
  bozo
  colour_map{[0.0  rgb 0.0]
             [0.3  rgb 0.0]
             [1.0  rgb 1.0]}
  scale 0.1
  turbulence 0.5
  isosurface {
    function { y
     -P(x,0,z).red*0.015
    threshold 1
    pigment { Wheat }
Mike Williams
Gentleman of Leisure
Date: 19 Oct 2004 23:20:26
Message: <4175d97a$1@news.povray.org>
Mike Williams nous apporta ses lumieres ainsi en ce 2004-10-19 03:15... :
>> isosurface {
>>   threshold 1
>>   pigment { Wheat }
>  isosurface {
>    function { y
>    threshold 1
>    pigment { Wheat }
>  isosurface {
>    function { y
>    threshold 1
>    pigment { Wheat }
> pigment{
>  bozo
>             [0.3  rgb 0.0]
>             [1.0  rgb 1.0]}
>  scale 0.1
>  turbulence 0.5
>  isosurface {
>    function { y
>     -P(x,0,z).red*0.015
>    threshold 1
>    pigment { Wheat }
I did that recently using a granite pattern. I had to scale it's
amplitude very small, *0.001, to get a good loking result, at *0.01 I
still had floating grains. The original used a granite normal. The end
result realy look like sand, more than the normal.
Date: 20 Oct 2004 09:03:03
Message: <vpP4lGA3vedBFwR0@econym.demon.co.uk>
>>>with isosurface.
>> pigment{
>>  bozo
>>             [0.3  rgb 0.0]
>>             [1.0  rgb 1.0]}
>>  scale 0.1
>>  turbulence 0.5
>>  isosurface {
>>    function { y
>>     -P(x,0,z).red*0.015
>>    threshold 1
>>    pigment { Wheat }
>Alain
If you got floating grains then you must have used
        y+Some_Function(x,y,z)
instead of
        y+Some_Function(x,0,z)
You should notice that in this bit:
>>    function { y
>>     -P(x,0,z).red*0.015
the y coefficients are all zero. This removes all possibility of the
grains being undercut or floating.
Mike Williams
