![](/i/fill.gif) |
Hello,
I have some difficulties to orient objects.
In helping me in, see the attached picture in 'povray.binaries.images'.
I have 12 hexagons (from 0 to B). I would like to draw a torus that
passes through the barycenters of two hexagons (the coordinates of
the barycenters are known).
In the image, i made it between hexagon '0' and hexagon '2'.
My calculations are :
- with barycenter of hexagone '0' : v0
- with barycenter of hexagone '2' : v2
- compute the normalized normal vector : vn=vnormalize(vcross(v0, v2));
- calc the lenght of v0 -> lv0
- convert rectangulars coordinates of vn -> azimuth and rise.
Now draw the torus :
torus {
lv0, 0.020
rotate (90-rise)*z
rotate -azimuth*y
pigment { color DarkTurquoise }
finish { ambient 0.40 diffuse 0.60 }
Work for this case, not with other pairs of hexagons.
It's not really a povray's question, probably more than mathematical :
Is my method of calculation is correct ?
How to properly orient my torus depending on the normal vector ?
Thanks
klp
![](/i/fill.gif) |
![](/i/fill.gif) |
Le 30/12/2011 17:13, kurtz le pirate nous fit lire :
> Hello,
Let's sum up: you have three points in space, two hexagons & origin.
you find the plane in which the three points are. (that's the vcross)
Then you need to move a torus to align with that plane.
I would suggest
#include "transforms.inc"
and using Reorient_Trans(y,vn)
![](/i/fill.gif) |
![](/i/fill.gif) |
In article <kurtzlepirate-285173.17130230122011@news.povray.org>,
kurtz le pirate <kur### [at] yahoo fr> wrote:
> Hello,
> [snip]
I found my mistakes :
first :
my rect_to_polar routine return the 'azimuth' with a wrong sign.
second :
rotations around y then around z is different from rotation around z
then around y.
Now that this issue is resolved, I can continue...
klp
![](/i/fill.gif) |
