POV-Ray : Newsgroups : povray.newusers : max(0,min(1,x)) Server Time
19 Sep 2025 02:10:13 EDT (-0400)
  max(0,min(1,x)) (Message 1 to 10 of 16)
Subject: max(0,min(1,x))
Date: 2 Oct 2002 08:10:16
Message: <Xns929B8FED09DB2raf256com@204.213.191.226>
Hello,
what is shourtcut function for max(a,min(b,x)) ?
btw. how about adding function
  limit1(a)
that will work as max(0,min(1,x))
ofcourse this can be done with macro - but hard-coded function will be
faster, and this construcion is quite frequent in i.e. patterns
Subject: Re: max(0,min(1,x))
Date: 2 Oct 2002 08:53:56
Message: <3d9aec64@news.povray.org>
There is no shortcut afaik.
Just use
#declare limit1= function(a) {max(0,min(1,a))}
or somethink like that.
Feel free to add this to your "functions.inc" or some other include-file you
are using frequently. There is really no need to build in everythink in the
Pov-Code.
Hth,
Marc-Hendrik
Date: 2 Oct 2002 09:05:24
Message: <Xns929B99469D7D9raf256com@204.213.191.226>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in
news:3d9aec64@news.povray.org
> Pov-Code.
speed ?
We have i.e. 1 room (inverted box) inside with we have camera, lightsource
and i.e. white sphere.
Box is covered with function with 1-3 constructions like
max(0,min(1,x+y...))
And now we add radiosity - fo reach pixel formula min(max(... must be
counted about 10..50 times depending on radiosity setting - that can
probably give 5-15% of render time lost. Hmm I guess I should just add this
minmax() function and see is speed improvment notacible :)
Date: 2 Oct 2002 10:01:21
Message: <3d9afc31@news.povray.org>
There's a clip() function in math.inc, if that's what you are talking
about.
Date: 2 Oct 2002 10:08:01
Message: <Xns929BA3E45DA24raf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d9afc31@news.povray.org
> about.
thanks
Just for couriosity I will modify it's code to work as
clip(0,1,x) (change variables to literal constants 0 and 1 should improve
speed a little bit) - in with file should I look ? (maybe function name ?)
Date: 2 Oct 2002 10:23:28
Message: <3d9b0160@news.povray.org>
> clip(0,1,x)
  Why don't you just make another function which does that instead of
modifying the standard function?
  Modifying the standard function is very dangerous, as it will potentially
break some scenes you might download.
  I said "math.inc", didn't I?
Date: 2 Oct 2002 10:36:35
Message: <Xns929BA8BC036CBraf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d9b0160@news.povray.org
>> clip(0,1,x)
just for a moment, before I learn how to add own function to syntax parser
source code
Date: 2 Oct 2002 10:47:12
Message: <3d9b06f0@news.povray.org>
> source code
  It will be hard to modify the clip() function in the source code, as
it's in defined in math.inc, not in the source code. :)
Date: 2 Oct 2002 10:51:50
Message: <Xns929BAB4FABA8Braf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d9b06f0@news.povray.org
>> source code
#declare clip = function (V, Mn, Mx) {min(Mx, max(V, Mn))}
woooow... this must be terrible slow in compare to hard-coded function.
With function takes 3 float argumetns, return float and is a real function
(not #decare/#macro) ?
Date: 2 Oct 2002 11:01:57
Message: <3d9b0a4f@news.povray.org>
  Do you want me to preach again about the advantages of using a macro or
function compared to a hard-coded feature?
  I can't imagine a scene where the speed-difference would be noticeable.
(Of course you could invent rather artificial examples, but I'm talking
about practical scenes.)
