POV-Ray : Newsgroups : povray.newusers : Radiosity artifacts... Server Time
19 Jan 2026 05:21:04 EST (-0500)
  Radiosity artifacts... (Message 1 to 3 of 3)
Subject: Radiosity artifacts...
Date: 13 Mar 2001 06:22:42
Message: <MPG.15181eed8d64f463989702@NEWS.POVRAY.ORG>
I simply never before had the courage to use radiosity in the scenes I'm
working on: interiors of a complex building. The big surprise was the
nice natural-looking lighting of the scene and the not much longer
render time. But:
I see artifacts on the lit ceiling and I could not find anything about
this although I seem to remember having read something about this
problem. The image is in p.b.I. and the radiosity setting is:
global_settings
  assumed_gamma 2.2
  ambient_light color rgb 0.1
  ini_option "+QR"
  radiosity
    recursion_limit 4
    brightness 1.0
    normal on
    error_bound 0.2
    pretrace_start 0.08
    pretrace_end 0.02
Possibly more data are required to see what is wrong, but I hesitate to
burden anybody with the spaghetti code I use... ;(
Question: what could be wrong?
Regards,  Sander
Subject: Re: Radiosity artifacts...
Date: 13 Mar 2001 07:13:15
Message: <3AAE0EDC.DBB2D6A6@gmx.de>
> render time. But:
Try increasing count (default is 35 IIRC) and maybe nearest_count.
If things become too slow or it uses very much memory i would reduce
recursion_limit, 2 or 3 instead of 4 is often not much worse.
Date: 13 Mar 2001 16:29:27
Message: <MPG.1518af9a5d4c87c0989706@NEWS.POVRAY.ORG>
In article <3AAE0EDC.DBB2D6A6@gmx.de>, Christoph Hormann says...
> Christoph
Thanks for your quick answer: I will do some experiments with those
settings. Chris Huff pointed me to the adverse effect of very bright
objects in the scene - which I had indeed! That I will also take care
of.
Regards,  Sander
