POV-Ray : Newsgroups : povray.newusers : Where is a bug ? Server Time
28 Mar 2026 16:46:39 EDT (-0400)
  Where is a bug ? (Message 1 to 10 of 16)
Subject: Where is a bug ?
Date: 1 Sep 2025 11:54:34
Message: <68b5c1ba$1@news.povray.org>
Hello,
The holidays are over. I've started a new project... which has me
confused. I don't understand POV's behavior.
The attached image illustrates the issue well. Both objects are defined
in the same way, but one is a union{} (magenta) and the other is a
merge{} (cyan).
It's a very very simple object: two boxes and four cylinders.
So, why le merged object (in cyan) show a hole ?
<sdl>
#declare S = 11.00;
#declare R = 3.00;
#declare H = 0.50;
#declare corner = cylinder { <0, -H, 0>, <0, 0, 0>, R }
merge or union
   box { <-S+R, -H, -S>, <+S-R, 0, +S> }
   box { <-S, -H, -S+R>, <+S, 0, +S-R> }
   object { corner translate <+(S-R), 0, +(S-R)> }
   object { corner translate <-(S-R), 0, +(S-R)> }
   object { corner translate <+(S-R), 0, -(S-R)> }
   object { corner translate <-(S-R), 0, -(S-R)> }
</sdl>
For the rendering, I added a translate 15*y for the cyan object but the
problem is not here.
If you have an idea...
Regards
ps : actually, I'm trying to understand how subsurface scattering works,
and I've already noticed that this feature requires merge{} because
union{} don't work, certainly due to surface coincidence.
kurtz le pirate
compagnie de la banquise
Download 'bug.png' (39 KB)
Preview of image 'bug.png'
Subject: Re: Where is a bug ?
Date: 1 Sep 2025 12:23:22
Message: <68b5c87a$1@news.povray.org>
Le 2025-09-01 à 11:54, kurtz le pirate a écrit :
> Hello,
> merge{} (cyan).
> <sdl>
> #declare S = 11.00;
> #declare R = 3.00;
> #declare H = 0.50;
> merge or union
> </sdl>
> Regards
The noise in the hole lead me to think that it may be a coincident
surface issue.
The merge remove internal surfaces. When two surfaces are in the exact
same location, you get all sort of glitches as the program can't tell
witch one is inside and need to get removed.
Try moving one of the box up or down by a very small amount, like :
translate y*10^-7
Does that help ?
Date: 1 Sep 2025 13:15:00
Message: <web.68b5d411b0e2b7faf625f77c25979125@news.povray.org>
> merge{} (cyan).
And that's the root of the problem:  it's TOO simple.
Remove the overlap of the two boxes by defining one central box, and adding FOUR
"leaves" or "wings" filling in the edges between the cylinder "corners".
Then I think it should work . . .
However, you may need to convert your corners from full cylinders to "pie
slices" by CSG - either home-rolled, or using Lohmueller's macro, which I
believe is in the drop-down insert menu as "segment of a cylinder"
-BE
(Perhaps do some other simple overlap tests to demonstrate what happens.)
Date: 1 Sep 2025 16:12:43
Message: <68b5fe3b$1@news.povray.org>
>> merge{} (cyan).
> -BE
For the overlap test, just make one of the boxes a different colour in
the union case. That will show the coincident surfaces.
union
   box { <-S+R, -H, -S>, <+S-R, 0, +S> pigment{rgb<0,1,0>}}
   box { <-S, -H, -S+R>, <+S, 0, +S-R> pigment{rgb<1,0,0>}}
   object { corner translate <+(S-R), 0, +(S-R)> pigment{rgb<0,0,1>}}
   object { corner translate <-(S-R), 0, +(S-R)> pigment{rgb<0,0,1>}}
   object { corner translate <+(S-R), 0, -(S-R)> pigment{rgb<0,0,1>}}
   object { corner translate <-(S-R), 0, -(S-R)> pigment{rgb<0,0,1>}}
This will make all coincident surfaces obvious.
Date: 1 Sep 2025 16:42:03
Message: <68b6051b$1@news.povray.org>
>> merge or union
> surface issue.
> translate y*10^-7
> Does that help ?
In fact, both boxes will need to be moved (one up, and one down),
because they also share coincident surfaces with the four cylinders.
P.S.  There is a typo: y*10^-7 should be y*10e-7.
Date: 1 Sep 2025 16:52:37
Message: <68b60795$1@news.povray.org>
>> merge{} (cyan).
I'm not sure this will solve the problem; it may just result in a
different set of coincident surfaces.
If you want to see what I went through to build this shape without
coincident surfaces, take a look at macro RE__box_axis() in this file:
  https://github.com/CousinRicky/POV-RoundEdge/blob/main/roundedge.inc
Date: 2 Sep 2025 03:09:11
Message: <68b69817$1@news.povray.org>
Thank you for all your answers.
In fact, it's still and still the same problem of surfaces coincidence.
Two boxes and four cylinders give too many cases to manage with epsilon
translation in y.
And as BE says, this object is “too” simple :(
So I started working on a new geometry with no overlap.
<sdl>
// --- a quarter circle
#declare corner = difference {
  plane { z,0 }
  plane { x, 0 }
merge {
   // central box
   box { <-S+R, -H, -S+R>, <+S-R, 0, +S-R> }
   // left/right box
   box { <-S+R, -H, -S>, <S-R, 0, -S+R> }
   box { <-S+R, -H, S-R>, <S-R, 0, S> }
   // front/rear box
   box { <S, -H, -S+R>, <S-R, 0, S-R> }
   box { <-S, -H, -S+R>, <-S+R, 0, S-R> }
   // corners
   object { corner scale <-1,1,1> translate <-(S-R), 0, +(S-R)> }
   object { corner scale <1,1,-1> translate <+(S-R), 0, -(S-R)> }
   object { corner scale <-1,1,-1> translate <-(S-R), 0, -(S-R)> }
</sdl>
Now everything seems fine.
I can restart my tests with SSS.
kurtz le pirate
Date: 3 Sep 2025 13:24:21
Message: <68b879c5$1@news.povray.org>
On 9/2/25 03:09, kurtz le pirate wrote:
> merge {
FWIW. An option, which might be faster than your merge{}, would be to
use a bezier_spline prism{}.
Bill P.
#version 3.8;
#declare Grey50 = srgb <0.5,0.5,0.5>;
background { Grey50 }
#declare Camera00 = camera {
     perspective
     location <3,3,-3.001>
     sky y
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare White = srgb <1,1,1>;
#declare Light00 = light_source { <50,150,-250>, White }
#declare Red = srgb <1,0,0>;
#declare CylinderX = cylinder { -1.1*x, 1.1*x, 0.01 pigment { Red } }
#declare Green = srgb <0,1,0>;
#declare CylinderY = cylinder { -1.1*y, 1.1*y, 0.01 pigment { Green } }
#declare Blue = srgb <0,0,1>;
#declare CylinderZ = cylinder { -1.1*z, 1.1*z, 0.01 pigment { Blue } }
#declare Orange = srgb <1,0.50196,0>;
#declare Bot    = 0.0;           // Base of prism linear sweep
#declare Top    = 0.2;           // Top of prism linear sweep
#declare Frac   = 0.2;           // portion of +-1.0 edges rounded
#declare Shft   = 1.0-Frac;      // Normalize to 1x1 range
#declare ShftUR = <+Shft,+Shft>; // Shift up and right
#declare ShftUL = <-Shft,+Shft>; // Shift up and left
#declare ShftLL = <-Shft,-Shft>; // Shift lower and left
#declare ShftLR = <+Shft,-Shft>; // Shift lower and right
#declare Prism00 = prism {
     bezier_spline
     linear_sweep
     Bot, Top, 32,
     <1,0>*Frac+ShftUR,<1,0.552285>*Frac+ShftUR,
     <0.552285,1>*Frac+ShftUR,<0,1>*Frac+ShftUR,
     <+Shft,1>,<+Shft+Shft/3,1>,<-Shft+Shft/3,1>,<-Shft,1>,
     <0,1>*Frac+ShftUL,<-0.552285,1>*Frac+ShftUL,
     <-1,0.552285>*Frac+ShftUL,<-1,0>*Frac+ShftUL,
     <-1,+Shft>,<-1,+Shft-Shft/3>,<-1,-Shft+Shft/3>,<-1,-Shft>,
     <-1,0>*Frac+ShftLL,<-1,-0.552285>*Frac+ShftLL,
     <-0.552285,-1>*Frac+ShftLL,<0,-1>*Frac+ShftLL,
     <-Shft,-1>,<-Shft+Shft/3,-1>,<+Shft-Shft/3,-1>,<+Shft,-1>,
     <0,-1>*Frac+ShftLR,<0.552285,-1>*Frac+ShftLR,
     <1,-0.552285>*Frac+ShftLR,<1,0>*Frac+ShftLR
     <+1,-Shft>,<+1,-Shft+Shft/3>,<+1,+Shft-Shft/3>,<+1,+Shft>
     pigment { Orange }
#declare PrismCylinder = prism {  // Bezier spline cylinder approx
     bezier_spline
     linear_sweep
     Bot, Top, 16,
     <1,0>,<1,0.552285>,<0.552285,1>,<0,1>
     <0,1>,<-0.552285,1>,<-1,0.552285>,<-1,0>
     <-1,0>,<-1,-0.552285>,<-0.552285,-1>,<0,-1>
     <0,-1>,<0.552285,-1>,<1,-0.552285>,<1,0>
     pigment { Orange }
//--- scene ---
     camera { Camera00 }
     light_source { Light00 }
     object { CylinderX }
     object { CylinderY }
     object { CylinderZ }
     object { Prism00 }
//  object { PrismCylinder }  // Bezier spline cylinder approx
Date: 3 Sep 2025 14:25:00
Message: <web.68b887b1b0e2b7faf5d731ff25979125@news.povray.org>
Dealing with chaos here, so I haven't thought this completely through...
But perhaps he could also use round box function / insert menu macro with
intersection, or my "rounded_box" (apparently unposted) variant with a very tiny
radius for the 2nd radius.
- BE
Date: 3 Sep 2025 21:35:46
Message: <68b8ecf2$1@news.povray.org>
Maybe... I thought too about the inbuilt f_rounded_box() function as an
iso briefly, but to get the straight vertical sides I think we'd have to
intersect with more or less the same corner shapes / box container being
used in posted merge{}. Perhaps we could build up the isosurface with
inbuilt, function similar shapes, matching what is in the merge. Whether
that would faster than the merge{}, I don't know.
Bill P.
