POV-Ray : Newsgroups : povray.newusers : Media density Server Time
16 May 2026 14:43:06 EDT (-0400)
  Media density (Message 1 to 10 of 23)
Subject: Media density
Date: 24 Jul 2016 04:19:12
Message: <57947a00$1@news.povray.org>
Some tests with media.
Whit this code :
hollow
pigment { rgbt 1 }
interior {
  media {
  emission 1.0
  density {
   spherical
   density_map {
    [ 0.00 rgb <0.39607808, 0.45490193, 0.97254896> ] // exterior
    [ 0.25 rgb <0.54705858, 0.59117645, 0.97941172> ]
    [ 0.50 rgb <0.69803905, 0.72745097, 0.98627448> ]
    [ 0.75 rgb <0.84901953, 0.86372548, 0.99313724> ]
    [ 1.00 rgb <1.00000000, 1.00000000, 1.00000000> ]
1) : images are same whit or without step 0.25,0.50,0.75 in density_map.
	Why ?
2) : here, spherical pattern is use for density. is it possible to use
other thing like gausssian curve for exemple. More generaly, how to
change pattern with f(x,y,z) for density pattern.
Thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Media density
Date: 24 Jul 2016 06:50:32
Message: <57949d78$1@news.povray.org>
> Whit this code :
> hollow
> pigment { rgbt 1 }
> interior {
>  media {
>  emission 1.0
>  density {
>   spherical
>   density_map {
>     Why ?
Have you tried more contrasting colours? I do that to check how the
pattern changes. Also be aware that in a density pattern colours are
interpreted as grey tints.
You can use any pattern you like and also warp. See for example my
sunset media in p.b.i. (there is an example there).
Date: 24 Jul 2016 09:15:00
Message: <web.5794be691a150b855e7df57c0@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
I'm not sure where the media and camera is in the scene, nor the scale.  I'd
either do a small separate test scene with your spherical pattern and color map,
or make a few temporary drastic changes to your scene to see "what gives"
I would guess it would just be something like this:
>   density {
    function (x, y, z) YourEquations.......
The docs have an "example" in the gradient pattern section.
" A more general solution is to use function{abs(x)} as a pattern instead of
gradient x and similar for gradient y and gradient z."
Date: 24 Jul 2016 10:02:03
Message: <5794ca5b$1@news.povray.org>
the complete scene :
// --- start ----------------------------------------------------------
global_settings {
  assumed_gamma 1.80
  max_trace_level 10
  location <10,0,0>
  up y
  look_at <0, 0, 0>
  angle 36
light_source {
  <1000,0,0>
  color White
background {
  color White*0
#declare radiusObject = 2.0;
#declare useSphere = true;
#declare displayEdge = false;
#if (useSphere)
  sphere {
  0, radiusObject
#else
  cylinder {
  <0,0,0>, <2,0,0>, radiusObject
  hollow
  pigment { rgbt 1 }
  interior {
   media {
    emission 1.0
    density {
     spherical
     density_map {
#if (displayEdge)
  torus {
  radiusObject, 0.01
  pigment { color Red }
  finish { ambient 0 emission 0.40 diffuse 0.60 }
  rotate 90*z
// --- end-------------------------------------------------------------
Kurtz le pirate
Date: 24 Jul 2016 10:20:26
Message: <5794ceaa$1@news.povray.org>
grey tints... interesting.
great exemples with 'standard' patterns.
I have difficulty understanding the relationship between the value of
the pattern and the value of the function and how to write pattern
function for Povray.
Classic equation for Gauss curve is :
                x^2     z^2
               2.a^2   2.b^2
   y = A.e
Povray documentation sample
(http://www.povray.org/documentation/view/3.6.1/378/) say :
#declare Foo = function { x + y + z}
   function { Foo(x, y, z) }
   [PIGMENT_MODIFIERS...]
So, #declare f_gauss = function { ? }
Thanks for your help.
Kurtz le pirate
Date: 24 Jul 2016 11:44:20
Message: <5794e254@news.povray.org>
Am 24.07.2016 um 10:19 schrieb kurtz le pirate:
>   density_map {
>     Why ?
Because those steps are just a linear interpolation of the values at
0.00 and 1.00? ;)
If you really want steps, you'll need to specify two colour values for
one and the same parameter values, e.g.:
density_map {
  [ 0.25 rgb <0.39607808, 0.45490193, 0.97254896> ]
  [ 0.50 rgb <0.54705858, 0.59117645, 0.97941172> ]
  [ 0.75 rgb <0.69803905, 0.72745097, 0.98627448> ]
  [ 1.00 rgb <0.84901953, 0.86372548, 0.99313724> ]
Look up "function pattern" (not to be confused with "pattern function").
Date: 24 Jul 2016 12:09:15
Message: <5794e82b$1@news.povray.org>
Am 24.07.2016 um 12:50 schrieb Thomas de Groot:
Actually, no, they're not. They do modify the media's effective colour.
Date: 24 Jul 2016 12:20:00
Message: <web.5794e9df1a150b855e7df57c0@news.povray.org>
It CAN get quite confusing.
I've actually spent most of last night and all of this morning doing just that.
I'd take a look at the isosurface tutorial in the documentation, as well as Mike
Williams' excellent and comprehensive tutorial:
http://www.econym.demon.co.uk/isotut/
and Friedrich Lohmueller's extensive and indispensable site:
http://www.f-lohmueller.de/pov_tut/addon/00_Basic_Templates/40_Isosurfaces_basic_functions/__index.htm
>                 x^2     z^2
>                2.a^2   2.b^2
>    y = A.e
Pardon my ignorance, but what is e, what is A, and what is your "dot notation" -
does that signify multiplication?
Date: 24 Jul 2016 13:00:01
Message: <web.5794f3b01a150b855e7df57c0@news.povray.org>
If you plan on doing a lot of mathematical visualization to work things out, I
keep running into this during my web searches on various topics and it looks to
be quite interesting:
http://euler-math-toolbox.de/Programs/03%20-%20Povray%20in%20Euler.html
It would be nice to supplement the docs with some scene files showing how some
of the more common as well as more complex and interesting 3D-plots can be
implemented in POV-Ray.
Add some trace(), eval_pigment(), and a few other tricks, and I'm sure there's
all sorts of fun to be had expanding on:
http://www.cescg.org/CESCG-2001/DBezak/page8.html
Date: 24 Jul 2016 13:30:00
Message: <web.5794faac1a150b855e7df57c0@news.povray.org>
>                 x^2     z^2
>                2.a^2   2.b^2
>    y = A.e
Based on:
https://en.wikipedia.org/wiki/Gaussian_function#Two-dimensional_Gaussian_function
my HSV color map:
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.56e1ce6a2f1b67735e7df57c0%40news.povray.org%3E/#%3Cwe
try this:
#declare X0 = 0;
#declare Z0 = 0;
#declare A = 1;
#declare a = 0.5;
#declare b = 0;
#declare c = 0.5;
#declare Gaussian = function {y - A * exp(   -( a*pow((x-X0),2) -
2*b*(x-X0)*(z-Z0) + c*pow((z-Z0),2) )   ) }
isosurface{ //------------------------- "sombrero"
  function {Gaussian (x, y, z)}
 open
  threshold 0
  contained_by{box{<-10, -1, -10>, <10, 1, 10>}}
  texture{
    pigment{ TempGradient scale <1, 1.1, 1>}
    //normal { ripples 0.5 scale 0.125}
    //finish { phong 1}
 translate <0, -0.1, 0>
  } // end of texture
  scale <1, 5, 1>
  rotate <0,0,0>
  translate <0, 0, 0>
} // end of isosurface ----------------
