POV-Ray : Newsgroups : povray.newusers : mesh2 with object pattern Server Time
22 Feb 2025 18:03:51 EST (-0500)
  mesh2 with object pattern (Message 1 to 3 of 3)
Subject: mesh2 with object pattern
Date: 14 May 2011 14:51:28
Message: <4dcecf30@news.povray.org>
I'm trying to use a mesh2 with the object pattern and I keep getting the
error "Illegal texture of patch in clip, bound, or object pattern".  The
mesh is untextured, has an inside_vector defined, and works fine in CSG.
  The object pattern also works fine if I use another object (such as a
sphere) instead of a mesh.  Any idea what I'm doing wrong?  This is
POV-Ray 3.6 on Vista in case that matters.
Here's some example source code that should generate the error:
#declare TestMesh = mesh2 {
   vertex_vectors {
     8,
     <-1,-1,-1>,
     <-1,-1,1>,
     <-1,1,-1>,
     <-1,1,1>,
     <1,-1,-1>,
     <1,-1,1>,
     <1,1,-1>,
     <1,1,1>
   face_indices {
     12,
     <0,1,2>, <1,2,3>,
     <4,5,6>, <5,6,7>,
     <0,1,4>, <1,4,5>,
     <2,3,6>, <3,6,7>,
     <0,2,4>, <2,4,6>,
     <1,3,5>, <3,5,7>
   inside_vector x
// This gives an error
sphere {
   <0,0,0>, 1
     object {
       object { TestMesh scale 0.5 translate <0,0,-1> }
       texture { pigment { color rgb 1 } }
       texture { pigment { color rgb <0,0,1> } }
Subject: Re: mesh2 with object pattern
Date: 14 May 2011 15:07:42
Message: <4dced2fe$1@news.povray.org>
Am 14.05.2011 20:51, schrieb Kevin Wampler:
You're not doing anything wrong - and yes, it does matter indeed. I can
confirm this as a bug in 3.62; seems ok with 3.7 release candidate.
Date: 14 May 2011 15:19:04
Message: <4dced5a8$1@news.povray.org>
I upgraded to 3.7 RC3 and everything works now.  Thanks!
