POV-Ray : Newsgroups : povray.newusers : Output file name with a scene parameter Server Time
7 Apr 2026 17:25:54 EDT (-0400)
  Output file name with a scene parameter (Message 1 to 10 of 12)
Subject: Output file name with a scene parameter
Date: 13 May 2010 13:03:00
Message: <4bec30c4$1@news.povray.org>
Hi All :)
Can we put in the output file name a parameter coming from the scene
file (.pov) ?
Eg: myScene_CAMERA2.bmp
with pov file named myScene.pov
and the parameter being "_CAMERA2"
Thanks
ALeX
Subject: Re: Output file name with a scene parameter
Date: 13 May 2010 13:13:44
Message: <4bec3348$1@news.povray.org>
Am 13.05.2010 19:02, schrieb Alex:
> file (.pov) ?
No.
What you can do, however, is automatically generate a batch file or
shell script to rename the output file, by using the #fopen and #write
SDL statements.
Date: 13 May 2010 13:29:14
Message: <4bec36ea$1@news.povray.org>
>> file (.pov) ?
> No.
> SDL statements.
Really ? According to the help #fopen is only for text file :s
Or the usage you give is not clear to me. Could you please develop your
idea ?
I prefer not using external (to POVRay) batch file...
Thank you ;-)
Date: 13 May 2010 13:34:01
Message: <4bec3809$1@news.povray.org>
>> file (.pov) ?
> No.
> SDL statements.
Here is my current 'solution':
I set vue to the appropriate view I want to compute.... but I get a
single picture while I would like to get for example views 0, 1 and 10....
#local vue =  3;
#switch (vue)
   #case (0) // Vue globale de face
     camera { location < 50, 170, -650 > look_at < 50, 170, 0 > }
     #break;
   #case (1) // Vue globale de face proche
     camera { location < 60, 10, -30 > look_at < 65, 5, 0 > }
     #break;
     camera { location < 80, 120, -150 > look_at < 60, 60, 0 > }
     #break;
     camera { location < 0, 0, -150 > look_at < 0, 0, 0 > }
     #break;
   #case (10) // Vue de dessous
     camera { location < 0, -50, 0 > look_at < 0, 0, 0 > }
     #break;
   #case (100) // Vue de de droite
     camera { location < 150, 50, -100 > look_at < 50, 50, 0 > }
     #break;
     camera { location < 250, 170, -50 > look_at < 50, 50, 50 > }
     #break;
     camera { location < -50, 0, 50 > look_at < 0, 0, 0 > }
     #break;
   #case (202) // Vue de de gauche avant
     camera { location < -50, 0, -50 > look_at < 0, 0, 0 > }
     #break;
Date: 13 May 2010 14:28:13
Message: <4bec44bd$1@news.povray.org>
Am 13.05.2010 19:29, schrieb Alex:
>> SDL statements.
> idea ?
Batch files and shell scripts /are/ "text files" in this sense; all you
need to do is choose a proper file extension (on Windows) or write a
proper "#!/bin/sh" line at the beginning to make the operating system
automatically recognize it as a script.
Then you're quite lost.
Note that there exist ini file options to specify a command to be run
after each frame or after the full render (or before, for that matter),
if it's a question of usability.
Date: 13 May 2010 17:37:56
Message: <4bec7134@news.povray.org>
> 10....
   Then you can create a pov scene for each value of "vue", just containing
the declaration and then including the rest of the scene.
   For example, the file "face_vue.pov" will contain:
   #local vue=0;
   #include "rest_of_the_sdl.pov"
   and so on for each value of "vue". Then simply queue all of them for
rendering... :)
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 13 May 2010 21:06:51
Message: <4beca22b$1@news.povray.org>
>>> file (.pov) ?
>> No.
>> SDL statements.
> #local vue = 3;
> #switch (vue)
> #break;
> #break;
> #break;
> #break;
> #break;
> #break;
> #break;
> #break;
> #break;
> #end
You can easily do an animation and get all the views.
Add +kff9 on the command line.
Replace #local vue = 3; by this:
#local vue = frame_number-1;
The internal variable frame_number starts at 1, so you need to substract
1 from it.
Change the cases larger than 3 to:
#case(4) in place of #case(10)
#case(5) in place of #case(100)
#case(6) in place of #case(101)
#case(7) in place of #case(201)
#case(8) in place of #case(202)
Where the last "n" will range from 1 to 8
Date: 15 May 2010 04:32:45
Message: <4bee5c2d$1@news.povray.org>
Oups, sorry, I confused threads with another post I've made in p.windows :))
But finally this matches, I just need to study animation mechanism (I
don't know yet)....
Thanks for your helpful tips :-)
ALeX
Date: 15 May 2010 04:52:14
Message: <4bee60be@news.povray.org>
>>>> file (.pov) ?
>>> No.
>>> SDL statements.
>> 10....
>> #local vue = 3;
>> #switch (vue)
>> #break;
>> #break;
>> #break;
>> #break;
>> #break;
>> #break;
>> #break;
>> #break;
>> #break;
>> #end
> 1 from it.
> Alain
Oups, thank you so much, but when you talk about command line, do you
mean I can't use the GUI ? I'm using POV-Ray with windows... Thus in
that case where to put this switch ?
Looking for in the same time...
Thanks,
ALeX
Date: 15 May 2010 05:03:00
Message: <4bee6344@news.povray.org>
>>>>> file (.pov) ?
>>>> No.
>>>> SDL statements.
>>> 10....
>>> #local vue = 3;
>>> #switch (vue)
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #break;
>>> #end
>> 1 from it.
>> Alain
> Thanks,
> ALeX
Ok, self response :)) Just played with frame number, 1 to 5 in INI file,
this is enough.
Just would be curious to find more about that famous command line :p
Another short question but out of that topic : can we have a separate
.ini file per scene file (.pov) ?
Merci :-)
