POV-Ray : Newsgroups : povray.newusers : Two questions about texture bitmaps Server Time
26 Mar 2026 15:00:16 EDT (-0400)
  Two questions about texture bitmaps (Message 1 to 6 of 6)
Subject: Two questions about texture bitmaps
Date: 20 Aug 2009 14:14:18
Message: <4a8d927a$1@news.povray.org>
Hi
Question #1:
How do I use a simple bitmap file as a simple texture on a simple box?
Sounds simple, doesn't it?
Question #2:
Why is there absolutely nothing about this in any documentation,
anything Google can find, no working examples, nothing?
Thanks
Timwi
Subject: Re: Two questions about texture bitmaps
Date: 20 Aug 2009 14:28:54
Message: <4a8d95e6$1@news.povray.org>
Timwi wrote:
> Question #1:
> Question #2:
Shortly after asking this, I discovered image_map. Please consider
improving the documentation for it so that it can be found. Currently it
makes no prominent mention of "bitmap" or "texture". Google searches for
anything containing these terms does not find it.
Thanks
Timwi
Date: 20 Aug 2009 14:37:35
Message: <4a8d97ef$1@news.povray.org>
Timwi schrieb:
> Question #1:
> Question #2:
Answer #1 and #2:
Check out section 3.5.1.5 "Image Maps" in the documentation.
As for mapping this onto a box, that section provides a general
description of how the image is mapped into 3D space (by default), which
should be so darn easy to adapt to mapping it onto a box that probably
authors of documentation and sample scenes deemed it too trivial to
provide examples:
By default, the image is mapped onto the x-y-plane. The image is
projected onto the object as though there were a slide projector
somewhere in the -z-direction. The image exactly fills the square area
from (x,y) coordinates (0,0) to (1,1) regardless of the image's original
size in pixels. If you would like to change this default you may
translate, rotate or scale the pigment or texture to map it onto the
object's surface as desired.
In the section "Checker", the checker pigment pattern is explained. The
checks are described as solid cubes of colored clay from which objects
are carved. With image maps you should imagine that each pixel is a
long, thin, square, colored rod that extends parallel to the z-axis. The
image is made from rows and columns of these rods bundled together and
the object is then carved from the bundle.
Date: 20 Aug 2009 14:39:30
Message: <4a8d9862@news.povray.org>
... not surprising given your terminology is not correct, so it is obvious
that by searching you cannot get the correct answer if you use incorrect
terms ;-)
Date: 20 Aug 2009 14:43:57
Message: <4a8d996d@news.povray.org>
If you have a good suggestion how to rephrase the section, you may want
to submit it to the POV-Ray wiki (http://wiki.povray.org), which is
actually where development of the 3.7 documentation takes place.
Date: 20 Aug 2009 15:17:40
Message: <4a8da154@news.povray.org>
"Timwi" <tim### [at] gmxnet> wrote in message news:4a8d95e6$1@news.povray.org...
> Timwi wrote:
>> Question #1:
>> Question #2:
>> Why is there absolutely nothing about this in any documentation, anything
Strange. I did a google for "povray bitmap texture" and the first site
returned was the POV_Ray Textures documentation which includes the syntax
for using bitmap based textures. That texture page also contains a link to
the "image map" amd "image pattern" pages in the documentation which
describe the use of images within pigment definitions. I would suggest that
the image_map page at http://www.povray.org/documentation/view/3.6.1/337/
probably describes the way that you wish to use image maps in POV-Ray.
If you wish to wrap your image around a simple box, then the section on
uv_mapping at http://www.povray.org/documentation/view/3.6.1/358/  describes
how that works. If you just want it to map to the front face (and run
through it like a stick of rock) then that's the default that Clipka has
described.
There are really quite a lot of ways of using image files in POV-Ray and
quite a lot of the documentation and various tutorials are dedicated to
them.
Chris B.
