POV-Ray : Newsgroups : povray.newusers : Lighting different when using equivalent isosurface Server Time
10 Jun 2026 14:42:14 EDT (-0400)
  Lighting different when using equivalent isosurface (Message 1 to 6 of 6)
Subject: Lighting different when using equivalent isosurface
Date: 20 Mar 2009 22:18:39
Message: <49c44e7f@news.povray.org>
I think I may have found a significant bug in POV-Ray, but if it's not a
bug then please explain to me why, and how I can work around the problem.
Consider the following source:
camera { location <2, 2, -5> look_at <0, 0.5, 0> }
light_source { <0, 3, 0> color rgb <0.7, 0.7, 0.7> }
#declare use_iso = 0;
difference {
     box { <-2.5, -1.1, -2.5>,
           < 2.5, 0,     2.5>
     #if(use_iso)
         // this isosurface _should_ be equivalent to the cylinder below
         isosurface {
             function { pow (x, 2) + pow (z, 2) - 4 }
             max_gradient 5.310
             accuracy .0001
             contained_by {
                 box { <-2.01, -1,  -2.01>,
                       < 2.01, .01,  2.01> }
     #else
         cylinder { <0, -1, 0>, <0, .01, 0>, 2 }
     pigment { Green }
Try rendering this with use_iso set to 0 and then with it set to 1. I
would have thought the two should produce pretty much the same result,
since the isosurface is equivalent to the cylinder.
But the result I get is this: with the cylinder everything works as
expected, but with the isosurface, the inside of the object is
completely black, even though there is a light source right next to it.
Is this a bug, or am I doing something wrong? If so, what?
Thanks
Timwi
Subject: Re: Lighting different when using equivalent isosurface
Date: 20 Mar 2009 23:45:34
Message: <IP2ElBBbLGxJFwW3@econym.demon.co.uk>
Wasn't it Timwi who wrote:
>Hi,
>a bug then please explain to me why, and how I can work around the
>problem.
>difference {
>          < 2.5, 0,     2.5>
>    #if(use_iso)
>        isosurface {
>            max_gradient 5.310
>            accuracy .0001
>            contained_by {
>    #else
>    #end
>    pigment { Green }
>Thanks
>Timwi
There's two things going on. One of them is you doing something wrong
and one could possibly be a bug.
When you perform CSG with an isosurface you must either set max_trace
appropriately or use all_intersections.
That still leaves the bottom of the hole darker when you use the
isosurface.
Mike Williams
Gentleman of Leisure
Date: 21 Mar 2009 10:46:01
Message: <49c4fda9$1@news.povray.org>
Thanks a lot... although it raises the question: why is that not the
default? Why is the default something that is, apparently, broken by
definition (because it doesn't calculate all intersections it needs to
generate the correct result)?
> isosurface.
Yeah. Should I report that as a bug?
In my case, I worked around it by having the isosurface cut a little bit
deeper and then filling up the bottom of the hole with another box...
but ideally, of course, I shouldn't have to do that.
Thanks
Timwi
Date: 21 Mar 2009 10:52:43
Message: <49c4ff3b@news.povray.org>
  Efficiency?
Date: 21 Mar 2009 11:15:00
Message: <web.49c5041f1daa10bf41685c200@news.povray.org>
As a matter of fact, POV 3.6 *does* produce identical results for cylinder and
isosurface version.
The current POV 3.7 beta renders properly if you add an "inverse" keyword to the
isosurface, for yet unexplained reasons. The beta page does not mention any
intentional change to isosurface behavior, and in fact only lists one single
change related to isosurfaces:
Changes between 3.7.beta.25 and 3.7.beta.26
Apply isosurface cache fix suggested by Lukas Winter in
<47c5b8b6$1@news.povray.org>.
So the cache fix might have broken something; however, it may already have been
broken earlier in the 3.7 development process of "C++-ifying" the code.
Date: 21 Mar 2009 11:35:01
Message: <web.49c508571daa10bf41685c200@news.povray.org>
It can have a significant performance advantage if the object is *not* used in
CSG (or, more specifically, differences or intersections), but directly at
scene level (or in unions).
(But then again, the user could still specify "max_trace 1" to benefit from that
speedup, so making all_intersections the default seems like a reasonable idea to
me. Maybe depending on the #version setting for backward compatibility.)
