POV-Ray : Newsgroups : povray.newusers : Applying a Border to a "triangle" Server Time
20 Dec 2025 07:58:40 EST (-0500)
  Applying a Border to a "triangle" (Message 1 to 8 of 8)
Subject: Applying a Border to a "triangle"
Date: 7 Jun 2008 07:40:58
Message: <484a73ca$1@news.povray.org>
How can I create a border of a specified width and color for a "triangle"
Finite_Patch Object having a different color?  I tried "merge" and "union"
of two different-size triangle and that doesn't want to compute.
If this can't be done, what is the slickest way to create a thin equilateral
"Finite Solid" triangle having a border edge and different color than the
remainder of the triangle?
Subject: Re: Applying a Border to a "triangle"
Date: 7 Jun 2008 08:44:59
Message: <484a82cb$1@news.povray.org>
"Catseye" <jpf### [at] comcastnet> wrote in message
news:484a73ca$1@news.povray.org...
There's lots of ways of doing this with a triangular object. Using a
different-size triangle is one that should work. You can use union but you
don't have to, just two differently scaled copies of the same triangle
should work just as well.
There are a couple of things that you'll need to get right though:
  o  When you scale the triangle it's easiest to do by translating it so
that it is centred at the origin, scale it and then translate it back again.
  o  You also need to avoid concurrent surfaces, so the smaller object
should be very slightly in front of the 'border' object (e.g.
translate -z*0.00001).
  o  If you are going to union them, then remember to apply the pigments to
the individual items and not to the union/merge.
If you want the triangle to show up on both surfaces on the triangle you can
use a third copy translated slightly in the opposite direction.
I'm not sure what a merge would produce because it removes internal surfaces
and I don't know what that would do with something like a bicubic_patch, a
mesh or a mesh2 etc.
> equilateral "Finite Solid" triangle having a border edge and different
> color than the remainder of the triangle?
This is possible too. You can use an object as a pigment, so, off the top of
my head, I would think the quickest way is probably to get the intersection
of 3 planes. Then define a pigment using that object:
#declare PlaneIntersectionObject =  intersection {
  plane {z,1}
  plane {z,1 rotate 120*y}
  plane {z,1 rotate 240*y}
  object {
    color rgb <1,0,0>  // Red Border
    color rgb <1,1,0>  // Yellow Triangle
You'd obviously then need to align it with your triangle object.
Chris B.
Date: 7 Jun 2008 09:14:51
Message: <484a89cb$1@news.povray.org>
Thanks Chris,
I get the impression from the user's manual discussion that CSG functions
like "merge" and "union" don't typically work with "patch" objects like
"triangle" and "disc".  That said, I have successfully used "difference" to
subtract a solid cylinder from a patch but I can't get two "patches" (in the
same plane) to "merge" or "union".
Any insight as to whether this is possible? - perhaps I'm overlooking some
basic protocol coding error.
If I comprehend what you are saying about the method to color the edge (90
degrees from the face) of a solid triangle; however that's not what I need.
If possible I need to be able to generate a border around the triangle face
(visible looking at the face the face).
I had already considered the compromise of translate-offsetting two
different sized triangles (of different colors) a miniscule amount as you
suggested, but I was looking for a more elegant solution.
Jim
"Chris B" <nom### [at] nomailcom> wrote in message
news:484a82cb$1@news.povray.org...
>> "union" of two different-size triangle and that doesn't want to compute.
> again.
> can use a third copy translated slightly in the opposite direction.
> surfaces and I don't know what that would do with something like a
> bicubic_patch, a mesh or a mesh2 etc.
> of my head, I would think the quickest way is probably to get the
> intersection of 3 planes. Then define a pigment using that object:
>  plane {z,1}
> pigment {
>  object {
> Regards,
> Chris B.
Date: 7 Jun 2008 10:16:20
Message: <016l44do023lm9t82u322pe80f9ig3bfdk@4ax.com>
On Sat, 7 Jun 2008 08:14:37 -0500, "Catseye" <jpf### [at] comcastnet>
PovRay does not support what you want but :)
Thibaut Jonckheere has created PovEdge which might help you.
http://tuabiht.chez-alice.fr/PovEdge_Site/PovEdge.html
See Harold on the road  and Harold #3 in povray.binaries.images
Regards
Date: 7 Jun 2008 10:48:39
Message: <484a9fc7$1@news.povray.org>
Thanks Stephen,
I had already explored the link on POV's home page.  It's touted to work
with "mesh2" objects.  Do you know if it also works also on
"triangle"-generated objects?
Jim
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:016l44do023lm9t82u322pe80f9ig3bfdk@4ax.com...
> Regards
>     Stephen
Date: 7 Jun 2008 11:20:20
Message: <484aa734@news.povray.org>
news:484a89cb$1@news.povray.org...
> need. If possible I need to be able to generate a border around the
> triangle face (visible looking at the face the face).
No that's not it. Using an object as a pigment colours everything outside
the conceptual 'object' one colour and everything inside the conceptual
'object' another colour. When such a pigment is applied to a surface you see
the outline of the section of the shape as the real object 'cuts through'
the pattern. In this case, if we slice the pattern at right angles we get a
yellow triangle with a red border. Here's a complete example using the
triangle object.
camera {location <0,2,-0.01> look_at 0}
light_source {   <-4,75 ,-10   >, rgb 1}
  plane {z,0.2}
  plane {z,0.2 rotate 120*y}
  plane {z,0.2 rotate 240*y}
triangle {
  <0,0,-2*0.3>, vrotate(<0,0,-2*0.3>,y*120), vrotate(<0,0,-2*0.3>,y*240)
    object {
Date: 7 Jun 2008 12:02:50
Message: <08cl44tgprm9n8s45f92uh5ds2dl8ds8dh@4ax.com>
On Sat, 7 Jun 2008 09:48:30 -0500, "Catseye" <jpf### [at] comcastnet>
wrote:
>Thanks Stephen,
I'm sorry Jim, I don't know.
Regards
Date: 7 Jun 2008 16:31:18
Message: <484af016$1@news.povray.org>
Perfect! - that's cool!
Thanks for sharing the example.
Jim
news:484aa734@news.povray.org...
>> (90 degrees from the face) of a solid triangle; however that's not what I
> see the outline of the section of the shape as the real object 'cuts
> through' the pattern. In this case, if we slice the pattern at right
> angles we get a yellow triangle with a red border. Here's a complete
> example using the triangle object.
>  plane {z,0.2}
> triangle {
>  pigment {
>    object {
