POV-Ray : Newsgroups : povray.newusers : Steps & Time Server Time
19 Dec 2025 00:25:54 EST (-0500)
  Steps & Time (Message 1 to 5 of 5)
Subject: Steps & Time
Date: 7 Aug 2007 04:25:02
Message: <46b82c5e$1@news.povray.org>
Hi all,
wonder if someone can suggest some methods for dealing with this:
Currently: Whenever I want to have multiple steps in a scene, I do something
like the following:
#declare Steps = 10;
#declare Step = floor(Steps*clock);
#declare Clock = mod(clock*Steps,1);
#if(Step=0)
    //Some rules for step 0 of the animation
#else
    //Some rules for after step 0, usually keeping an object stable
As you can imagine, this becomes cumbersome very quickly if an object is
doing different things in each step - and it means a lot of nested IFs. In
the demo above, the steps are all of even Length, but that is easily
resolved with a bit of logic and an array.
An alternative that sprang to mind was just to copy/paste into multiple
scenes but that means that if I decide to change something in a previous, I
have to propogate my changes up and down the timeline - also cumbersome.
Any pointers would be greatly appreciated
(whilst writing this I realised there should be a switch statement of some
kind and *tada* there is - but still, if anyone has any suggestions, please
let me know)
Subject: Re: Steps & Time
Date: 7 Aug 2007 05:57:21
Message: <46b84201$1@news.povray.org>
Simon nous apporta ses lumieres en ce 2007/08/07 04:24:
> Hi all,
> like the following:
> #if(Step=0)
> #else
> #end
> let me know)
Take a look at the #switch(...) #case(...) #range(...) #break structure.
3.2.2.6.3  The #switch, #case, #range and #break Directives
  My bologna has a first name.
                    Oscar Mayer
Date: 7 Aug 2007 07:55:32
Message: <46b85db4@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> wrote in message
news:46b82c5e$1@news.povray.org...
> Hi all,
> something like the following:
> #if(Step=0)
> #else
> #end
> I have to propogate my changes up and down the timeline - also cumbersome.
> please let me know)
Hi Simon,
Lots of alternatives spring to mind.
Basically anything that can return a number (or numbers) can be used to
control an animation, so you could look at using functions, macros, splines
etc. You may be able to avoid 'if' statements and 'switch' statements by
using your 'step' variable as the index to an array. For example, you could
set up an array from 0 to 10 with values such as
0,0,0,0.1,0.3,0.5,0.7,0.9,1,1 and then use the value of your 'step' variable
to retrieve a value from the array. You could then use that value to
retrieve the coordinates at that distance along a spline or along a sine
wave or a normal at a point on a surface (trace) or a colour at a point in
space in a pigment (eval_pigment) etc. etc.
You can then do whatever you want with that number/coordinate/normal/colour.
With the above example you could use the position along a spline to control
a camera position, so that it stays still for the first 3 'steps',
accelerates along the spline and stops for a while at the end, or, if the
spline stays within a box from <0,0,0> to <1,1,1>, you could use the
'position' on the spline as the colour of an object.
Hope this inspires some ideas but be careful not to get too wacked out on
psychedelia.
Chris B.
Date: 7 Aug 2007 13:46:01
Message: <46b8afd9$1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:46b85db4@news.povray.org...
>> Hi all,
>> #if(Step=0)
>> #else
>> #end
>> In the demo above, the steps are all of even Length, but that is easily
>> cumbersome.
>> some kind and *tada* there is - but still, if anyone has any suggestions,
>> please let me know)
> Hi Simon,
> splines etc. You may be able to avoid 'if' statements and 'switch'
> statements by using your 'step' variable as the index to an array. For
> example, you could set up an array from 0 to 10 with values such as
> variable to retrieve a value from the array. You could then use that value
> to retrieve the coordinates at that distance along a spline or along a
> sine wave or a normal at a point on a surface (trace) or a colour at a
> point in space in a pigment (eval_pigment) etc. etc.
> number/coordinate/normal/colour. With the above example you could use the
> position along a spline to control a camera position, so that it stays
> still for the first 3 'steps', accelerates along the spline and stops for
> a while at the end, or, if the spline stays within a box from <0,0,0> to
> <1,1,1>, you could use the 'position' on the spline as the colour of an
> object.
> psychedelia.
> Regards,
> Chris B.
Thanks very much Chris, the array idea really appeals to me. I'll need to
sit and ponder how best to utilise it - what springs to mind is having an
array of stings that are evaluated in place based on the Step. I may end up
using a micture of this and the if/switch/etc... to come to some sort of
hybrid. I'll also look into using a function.
Thanks again for the input, it's greatly appreciated.
Simon
Date: 7 Aug 2007 15:25:46
Message: <46b8c73a$1@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:46b84201$1@news.povray.org...
>> Hi all,
>> #if(Step=0)
>> #else
>> #end
>> cumbersome.
>> please let me know)
> Alain
>                    Oscar Mayer
Alain, many thanks! I must admit I never realised how flexible the switch
statement was! This definitely seems to be the way to go (although I'll also
be looking into Chris's ideas).
I just want to thank you both for your advice.
S
