POV-Ray : Newsgroups : povray.newusers : fog-in-a-box? Server Time
19 Dec 2025 00:25:53 EST (-0500)
  fog-in-a-box? (Message 1 to 7 of 7)
Subject: fog-in-a-box?
Date: 1 Aug 2007 10:21:41
Message: <46b096f5$1@news.povray.org>
Would it be possible to somehow create fog-in-a-box?
Phone: +31-6-41278122, PGP-key: 1F28D8AE, www.vanheusden.com
Subject: Re: fog-in-a-box?
Date: 1 Aug 2007 11:24:04
Message: <46b0a594@news.povray.org>
http://povray.org/documentation/view/3.6.1/416/
Date: 1 Aug 2007 11:34:19
Message: <46b0a7fb$1@news.povray.org>
That's light fall-off, that's different from fog as fog is more or less
random.
Date: 1 Aug 2007 11:36:24
Message: <46b0a878@news.povray.org>
> random.
  Says who?-)
  If you want fog with varying density,
http://povray.org/documentation/view/3.6.1/419/
http://povray.org/documentation/view/3.6.1/94/
Date: 1 Aug 2007 17:14:36
Message: <46b0f7bc$1@news.povray.org>
Folkert van Heusden nous apporta ses lumieres en ce 2007/08/01 11:34:
> random.
In my experience with RL fog, when there is little to no wind, fog is prety
uniform. Otherwize, it tend to comform to the turbulence in the air flow.
Just fill a box with scattering media, add "hollow" to allow the box to contain
that media. If you want non-uniform fog, add a density statement with some
pattern, like bumps or granite, optionaly with some turbulence.
I bet exercise equipment would be a lot more
expensive if we had evolved from starfish.
Date: 1 Aug 2007 17:52:02
Message: <46b10082@news.povray.org>
Folkert van Heusden wrote:
> Hi,
Yes, it is indeed possible, and you will get effects unlike those which
  media or attenuation produce. This code works:
fog{rgb 1 distance 4 }
box{<-5,-4,-5>,<5,4,5>
  pigment{rgbt 1}
  inverse
  rotate y*25
If you want fog in the rest of your scene, some complex csg operations
will be needed.
Hope it helps~
~Sam
Date: 1 Aug 2007 19:35:49
Message: <46b118d5@news.povray.org>
Samuel Benge nous apporta ses lumieres en ce 2007/08/01 17:52:
>> Hi,
>  pigment{rgbt 1}
>  inverse
>  rotate y*25
> will be needed.
> Hope it helps~
> ~Sam
Only work if the camera is inside the box. If the camera is outside, you must
use a difference with the box and another object around the camera. That object
must have texture{color{rgbt 1}finish{ambient 0 diffuse 0}}.
