POV-Ray : Newsgroups : povray.newusers : --- Server Time
8 Apr 2026 10:25:07 EDT (-0400)
  --- (Message 1 to 3 of 3)
Subject: ---
Date: 12 Jul 2007 18:37:35
Message: <4696ad2f@news.povray.org>
I was using a difference of a plane and a box, but then I realized that for
what I wanted to do I could just use a plane with an image_pattern with the
once keyword, but I was wondering what is the most memory efficient or speed
efficient method, CSG difference or intersection, plane + image_pattern +
once, or the polygon or mesh? the work that I've been doing latelly has used
flat images almost exclusivelly (and transparency), so any speed saving
technique would be much appreciated.
Subject: Re:
Date: 13 Jul 2007 09:59:05
Message: <46978529@news.povray.org>
Veggiet nous apporta ses lumieres en ce 2007/07/12 19:40:
A plane is very effecient. If your scene contains any media or fog, then, you
must also use the hollow keyword if you want it to apears behind your image.
A 2 triangles mesh is also quite effecient, especialy if you need 10's or 100's
of copies of it. This is due to instancing of identical meshes, that can be
individualy scaled, translated and rotated.
A polygon is less optimised. Fast but taking slightly more memory.
A difference or intersection is less effecient both in speed and memory use, but
only slightly in a simple case.
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
An Hourglass is Female, because over time, the weight shifts to the bottom.
Subject: Re: Re:
Date: 13 Jul 2007 11:14:11
Message: <469796c3@news.povray.org>
  Not in large numbers. That's because a plane is not bound.
