POV-Ray : Newsgroups : povray.newusers : optic guide. Server Time
17 Aug 2025 15:19:38 EDT (-0400)
  optic guide. (Message 1 to 10 of 14)
Subject: optic guide.
Date: 9 Jun 2007 07:57:43
Message: <466a95b7$1@news.povray.org>
I want to desing a optic guide for en LED.
It is possible to simulated this with povray?
I can not see where I can change specification of material to define the
guide.
I am play with led source but not manage to make a led with 10degres angle.
Best regard
Thierry
Subject: Re: optic guide.
Date: 9 Jun 2007 08:41:40
Message: <466aa004@news.povray.org>
466a95b7$1@news.povray.org...
> guide.
> angle.
> Best regard
> Thierry
Could you be more precise on what you want to achieve?
What is a LED optic guide?
Marc
Date: 9 Jun 2007 09:29:17
Message: <99el63tv320rev1449l9h32n5vgskov7p7@4ax.com>
On Sat, 9 Jun 2007 13:57:43 +0200, "TP Electronics" <tp### [at] tpelectronicsno> wrote:
>guide.
>Best regard
>Thierry
I don't think that fibre optics (if that is what you mean) can be done in
Pov-Ray, not without faking it.
Regards
Date: 9 Jun 2007 09:59:08
Message: <466ab22c$1@news.povray.org>
I might be wrong but using ior and rising the max_trace_level in the
global settings should do the trick.
But only if the border angle where the refraction turns into reflection
is used in POVRAY, which I don't know (yet).
It should be easy to write a test code ...
>> guide.
>> Best regard
>> Thierry
> Regards
> 	Stephen
Date: 9 Jun 2007 10:27:17
Message: <466ab8c5$1@news.povray.org>
There is a test render at p.b.images
I think it works but don't ask me how good it is for real optics
applications ...
> guide.
> Best regard
> Thierry
Date: 9 Jun 2007 11:45:03
Message: <466acaff$1@news.povray.org>
To answer to Marc.
I am design a panel unit with 7 switch/ key. custormer will at when the key
is activ, the key ligthing.
I have place 2 light source ( LED ) between the switch and want desing a
knopp to active the switch and guide the light of LED to the top.
I will try differente form of knopp to have the best light on the top.
I have read the manuel with ligth source, try som but have not some result.
I am not a prof with povray, I am using Povray with the CAD software eagle
to show som 3D pictures of my board.
I will try all tips you write.
"TP Electronics" <tp### [at] tpelectronicsno> skrev i melding
news:466a95b7$1@news.povray.org...
> guide.
> angle.
> Best regard
> Thierry
Date: 9 Jun 2007 12:53:31
Message: <466adb0b@news.povray.org>
466acaff$1@news.povray.org...
> To answer to Marc.
> key is activ, the key ligthing.
> result.
I think you won't get accurate simulation of that guide.
Usually it is try and error process to get what we want.
But maybe you could try a pigment with filter 1
like :
pigment {color rgb 1 filter 1}
or shorter
pigment {color rgbf 1}
It is hard to give code without knowing exactly what you want :-)
Marc
Date: 9 Jun 2007 13:57:32
Message: <466aea0c$1@news.povray.org>
ok thanks marc.
It is do not what I espect.
I understand at it is perhaps not povray SW to do this simulation.
Thierry
"Marc" <jac### [at] wanadoofr> skrev i melding
news:466adb0b@news.povray.org...
>> To answer to Marc.
>> result.
>> eagle to show som 3D pictures of my board.
> like :
> or shorter
> Marc
Date: 9 Jun 2007 15:08:05
Message: <466afa95$1@news.povray.org>
Hi Thierry,
did have a look at
> news://news.povray.org:119/466ab87b@news.povray.org
Is that what you want ...
Marc Schimmler
Date: 9 Jun 2007 16:30:01
Message: <web.466b0ce3cb54bcb6e33c01c00@news.povray.org>
> guide.
> Best regard
> Thierry
Do you mean one of those clear plastic prisms that brings light from the LED
up to the front of a piece of consumer-electronics?  You might try enabling
photons and setting the optic guide as a "target."
http://www.povray.org/documentation/view/3.6.1/425/
Also see the insert-menu item "Photons scene" under "scene templates" (if
you're using Windows)for a good demonstrations of using photons.
I haven't tried it, but I have a feeling you may also need a
double-illuminated surface for the photons to hit after going through the
prism.  Again, I'm not sure if this is what you are looking for, and I
haven't tried what I am suggesting.
Charles
