POV-Ray : Newsgroups : povray.newusers : repeat an object with different scaling and position Server Time
17 Aug 2025 22:21:54 EDT (-0400)
  repeat an object with different scaling and position (Message 1 to 7 of 7)
Subject: repeat an object with different scaling and position
Date: 14 Mar 2007 10:31:03
Message: <45f81537@news.povray.org>
Hi there
I'm quite new in povray, so I tried to search the list for this but without
any luck. Here we go..
I have an object - a sphere - which I want to have repeated at different
sizes and at different positions to simulate bubbles in water. I got the
water and a single bubble looking the way I want but is there a simpler way
to repeat this object making the scale and position changing at random?
Thanks in advance
/Nikolaj
Subject: Re: repeat an object with different scaling and position
Date: 14 Mar 2007 10:48:31
Message: <45f8194f@news.povray.org>
"Nikolaj K. Holm" <hej### [at] hotmailcom> wrote in message
news:45f81537@news.povray.org...
> Hi there
> without any luck. Here we go..
> way to repeat this object making the scale and position changing at
> random?
check out the thread Objects on a slope in Povray.General you might be able
to glean something from that.
Jim
Date: 14 Mar 2007 12:38:56
Message: <45f83330@news.povray.org>
  Could you please specify if the problem you are having is copying
objects in general, or just creating some formula which places objects
randomly according to a certain pattern?
Date: 14 Mar 2007 14:16:34
Message: <45f84a12@news.povray.org>
news:45f83330@news.povray.org...
>> way
sounds like he described it pretty clear to me so that's why I pointed him
at the thread you helped me with ..... part of that code has a little dither
routine that scales, rotates, and then places it randomly in a given area
.... just take out the stuff about trace
Jim
Date: 14 Mar 2007 14:47:38
Message: <45f8515a$1@news.povray.org>
Actually, your search could have turned up my recent
sparkling water experiments:
http://news.povray.org/povray.binaries.images/message/%3C45d0d486%40news.povray.org%3E/#%3C45d0d486%40news.povray.org%3E
Here is a snippet of SDL to show how I generated the bubble object
which is to be subtracted from the liquid). Note that all bubbles
form one blob object, which renders a lot faster but is not really
perceptibly different from using individual bubbles.
#declare GLASS_RADIUS   = 0.70;
#declare WATER_LEVEL    = 2.80;
#declare BUBBLE_COUNT   = 600;
#declare BUBBLE_RADIUS  = 0.03;
#declare R = seed(42);
#declare BUBBLE_SHAPE = blob
   #local i = 0;
   #while (i < BUBBLE_COUNT)
     #local phi = 2*pi*rand(R);
     #local d   = rand(R) * GLASS_RADIUS;
     #if (d > GLASS_RADIUS)
       #local d = GLASS_RADIUS; /* 50% of bubbles at rim */
     #local h   = rand(R) * WATER_LEVEL;
     #local r   = 0.5 + 0.5 * rand(R);
     #local r   = r * r * BUBBLE_RADIUS; /* More small bubbles */
     sphere {d*<cos(phi),0,sin(phi)> + h*y,r,1}
     #local i = i + 1;
   threshold 0.6
Date: 14 Mar 2007 14:55:48
Message: <45f85344$1@news.povray.org>
>     #end
Oops, ignore these lines, they actually no longer have any
effect (or insert a factor > 1 in the calculation of d).
Date: 15 Mar 2007 09:44:02
Message: <45f95bb2$1@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> skrev i en meddelelse
news:45f8515a$1@news.povray.org...
>> random?
>   #local i = 0;
>     #end
>     #local i = i + 1;
>   #end
>   threshold 0.6
Thanks a lot - don't know why it didn't came up in my search. Guess it
depends on what you type in as search terms ;-)
Anyway - it works fine, so I'm one happy little ray-tracer now :o)
