POV-Ray : Newsgroups : povray.newusers : A perplexity... Server Time
11 Jul 2026 08:09:18 EDT (-0400)
  A perplexity... (Message 1 to 9 of 9)
Subject: A perplexity...
Date: 30 Oct 2005 13:08:46
Message: <43650D4E.E1E95902@daeoria.org>
I'm playing with gems.  (I "wish" they were the real thing.  Just POV
stuff, though.)
I'm observing some anomolous (to me) behavior.  I'm using a declaration
to define the gem structure.  If I use an "intersection" of box objects,
I get a dirty or noisy material as a result.  If I use an intersection
of planes, I get a very clean crystaline result.  The code and resultant
images are below.
Using planes...
#declare xAngle = 45.0;
#declare yAngle = 45.0;
#declare zAngle = 45.0;
#declare xPlane = 1.0;
#declare yPlane = 1.0;
#declare zPlane = 1.0;
#declare CrystalJewel = intersection
   plane { x, xPlane }
   plane {-x, xPlane }
   plane { y, yPlane }
   plane {-y, yPlane }
   plane { z, zPlane }
   plane {-z, zPlane }
   plane { x, xPlane rotate  xAngle*y }
   plane {-x, xPlane rotate  xAngle*y }
   plane { x, xPlane rotate -xAngle*y }
   plane {-x, xPlane rotate -xAngle*y }
   plane { y, yPlane rotate  yAngle*z}
   plane {-y, yPlane rotate  yAngle*z}
   plane { y, yPlane rotate -yAngle*z}
   plane {-y, yPlane rotate -yAngle*z}
   plane { z, zPlane rotate  zAngle*x}
   plane {-z, zPlane rotate  zAngle*x}
   plane { z, zPlane rotate -zAngle*x}
   plane {-z, zPlane rotate -zAngle*x}
   bounded_by {sphere {0, 1.7321}}
   no_shadow
Using boxes...
#declare BrilliantJewell = intersection
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate -45*x }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate  45*x }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate -45*y }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate  45*y }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate -45*z }
   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate  45*z }
   #if (clock_on)
      rotate frame_number * (360/final_frame)
   no_shadow
The texture and interior definitions are identical, I just swap out one
or the other () declarations from above using the below macro...
#macro Jewel( t_, i_ )
object
   CrystalJewel //Octahedron
   texture { t_ }
   interior { i_ }
The result using boxes...
[Image]
The result using planes...
[Image]
Why cant I get the same result using a box as I can using plane objects?
Thanks for your input.
- Patrick
Subject: Re: A perplexity...
Date: 30 Oct 2005 13:12:36
Message: <43650E32.4CAFE6DC@daeoria.org>
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Oops!  My images didn't see to upload.
<p>Trying again.  Using boxes...
<br><img SRC="cid:par### [at] daeoriaorg" height=141 width=291>
<p>Using planes...
<p>Patrick Hagerty wrote:
<blockquote TYPE=CITE>I'm playing with gems.  (I "wish" they were
<br>stuff, though.)
<p>I'm observing some anomolous (to me) behavior.  I'm using a declaration
<br>to define the gem structure.  If I use an "intersection" of box
objects,
<br>I get a dirty or noisy material as a result.  If I use an intersection
<br>of planes, I get a very clean crystaline result.  The code and
resultant
<br>images are below.
<p>Using planes...
<p>// ----------------------------------------
<br>// ----------------------------------------
<br>#declare xAngle = 45.0;
<br>#declare yAngle = 45.0;
<br>#declare zAngle = 45.0;
<br>#declare xPlane = 1.0;
<br>#declare yPlane = 1.0;
<br>#declare zPlane = 1.0;
<br>#declare CrystalJewel = intersection
<br>{
<br>   plane { x, xPlane }
<br>   plane {-x, xPlane }
<p>   plane { y, yPlane }
<br>   plane {-y, yPlane }
<p>   plane { z, zPlane }
<br>   plane {-z, zPlane }
<p>   plane { x, xPlane rotate  xAngle*y }
<br>   plane {-x, xPlane rotate  xAngle*y }
<p>   plane { x, xPlane rotate -xAngle*y }
<br>   plane {-x, xPlane rotate -xAngle*y }
<p>   plane { y, yPlane rotate  yAngle*z}
<br>   plane {-y, yPlane rotate  yAngle*z}
<p>   plane { y, yPlane rotate -yAngle*z}
<br>   plane {-y, yPlane rotate -yAngle*z}
<p>   plane { z, zPlane rotate  zAngle*x}
<br>   plane {-z, zPlane rotate  zAngle*x}
<p>   plane { z, zPlane rotate -zAngle*x}
<br>   plane {-z, zPlane rotate -zAngle*x}
<p>   bounded_by {sphere {0, 1.7321}}
<br>   no_shadow
<br>}
<p>Using boxes...
<br>#declare BrilliantJewell = intersection
<br>{
<br>   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> }
<br>   box { <-1.0, -1.0, -1.0>, <1.0, 1.0, 1.0> rotate
-45*x }
45*x }
-45*y }
45*y }
-45*z }
45*z }
<p>   #if (clock_on)
<br>      rotate frame_number * (360/final_frame)
<br>   #end
<p>   no_shadow
<br>}
<p>The texture and interior definitions are identical, I just swap out
one
<br>or the other () declarations from above using the below macro...
<br>#macro Jewel( t_, i_ )
<br>object
<br>{
<br>   CrystalJewel //Octahedron
<p>   texture { t_ }
<br>   interior { i_ }
<br>}
<br>#end
<p>The result using boxes...
<br>[Image]
<p>The result using planes...
<br>[Image]
<p>Why cant I get the same result using a box as I can using plane objects?
<p>Thanks for your input.
<p>- Patrick</blockquote>
</html>
Download 'c:\windows\temp\nsmail94.png' (70 KB) Download 'c:\windows\temp\nsmailob.png' (33 KB)
Preview of image 'c:\windows\temp\nsmail94.png'
Preview of image 'c:\windows\temp\nsmailob.png'
Date: 30 Oct 2005 14:52:01
Message: <SVQ3aJAYRSZDFw9T@econym.demon.co.uk>
>stuff, though.)
>images are below.
What's happening is that a box rotated by +45 is exactly the same as a
box rotated by -45, so you're getting the coincident surface problem.
See "2.4.2.5  Why are there strange dark pixels or noise on my CSG
object?" in the documentation.
If you delete three of the rotated boxes in your intersection it will be
the same shape but without most of the speckles. The remaining speckles
are caused by the fact that each of the rotated boxes have two faces
that are coincident with the unrotated box. E.g. the box that's rotated
by y*45 has the top and bottom face still in the same plane.
You can fix that by making the first box have a slightly different size.
   box { <-1.0001, -1.0001, -1.0001>, <1.0001, 1.0001, 1.0001> }
By the way: Don't post images to this newsgroup. Binary files should
only be posted to a .binaries newsgroup.
Mike Williams
Gentleman of Leisure
Date: 30 Oct 2005 17:45:58
Message: <43654E48.962996E9@daeoria.org>
Of course!  I did the "plane" method first and forgot that I'm dealing with
more surfaces with boxes than I am with planes.
Thanks!
> >stuff, though.)
> >images are below.
> Mike Williams
Date: 30 Oct 2005 17:54:41
Message: <43655054.BFA2ECB2@daeoria.org>
OK.  I tried it.  It worked.
I was simply failing to think in three dimensions.  A plane is two dimensional,
a box is three dimensional.  That's what I get for doing most of my POV-Ray
work in the evening after a day of mind numbing work.
Thanks again.
> Thanks!
> > >stuff, though.)
> > >images are below.
> > Mike Williams
Date: 30 Oct 2005 19:43:43
Message: <436568bf@news.povray.org>
Just a heads-up for the next time: images belong into
povray.binaries.images, its standard behaviour here to upload the image
there with a comment like "In regard to the thread entitled ... in ...".
Tim
aka "Tim Nikias v2.0"
Date: 31 Oct 2005 03:10:09
Message: <4365d161$1@news.povray.org>
"Patrick Hagerty" <pat### [at] daeoriaorg> wrote in message
news:43655054.BFA2ECB2@daeoria.org...
> dimensional,
> POV-Ray
> Thanks again.
Hello Pat,
Not meaning to be a pain, and it doesn't impact your gem solution, but just
to explain pedantically in order to be safe...  In PovRay's Constructive
Solid Geometry, a plane is considered a 3-Dimensional object - ie. like a
box, the plane has an inside and an outside, except the inside of a plane
extends infinitely.  A triangle or polygon, however is two-dimensional - it
has no inside nor outside.
If you invert the normal of the plane, eg, from y to -y, the plane will look
identical, however "inside" and "outside" are reversed.  This will make a
big difference to the behaviour of unions, intersections and differences.
It also impacts on media.
Cheers,
   Brian
Date: 31 Oct 2005 16:43:32
Message: <43669124.3C9B09F3@daeoria.org>
Brian,
Thanks a lot.  That's really good to know.
I'd appreciate your input, if you don't mind.  I'm getting ready to launch into
a new round of gem experimentation. (I started with the planes, then tried boxes
and had the problem I started this thread about.)  I'm thinking about using a
mesh object to attempt a more complex and more extensively faceted gem.  Do have
any thoughts or warnings you'd care to share as I get ready to attempt this?
- Patrick
> > dimensional,
> > POV-Ray
> > Thanks again.
> Hello Pat,
> Cheers,
>    Brian
Date: 31 Oct 2005 16:45:53
Message: <436691B1.E7927167@daeoria.org>
Acknowledged, sir.  I will be sure to do so in the future, and I extend my
apologies to all for violating protocol.
- Patrick
> Regards,
> Tim
> Homepage: <http://www.nolights.de>
