POV-Ray : Newsgroups : povray.newusers : Model a real world camera Server Time
10 Apr 2026 05:21:15 EDT (-0400)
  Model a real world camera (Message 1 to 2 of 2)
Subject: Model a real world camera
Date: 24 Jul 2005 06:26:01
Message: <42e36cb9@news.povray.org>
Hello,
I'm new to PovRay, and I'm using it to create some test images for a robot
localization problem. I want to model the camera the robot has. I've
searched the newsgroups and googled but I haven't found the right way to do
it.
As you cannot specify the focal lenth of the camera it has to be done
through the other parameters.
This is what I've written but it doesn't work:
#declare size_width = 768;
#declare size_height = 576;
#declare ccd_w = 2.7;
#declare ccd_h = 3.6;
#declare resolution_x = ccd_w / size_width;
#declare resolution_y = ccd_h / size_height;
#declare focal_length =  3.5;
#declare fov_angle =  42.18;
#declare camera_position = <0, 5, 5>;
#declare viewing_direction =   <0, 4, 0>;
 location camera_position
 right <-size_width*resolution_x,0,0>
 up <0,-(size_height*resolution_y),0.0>
 angle         fov_angle
 look_at        viewing_direction*20
The FoV angle is calculated with the formula:
fov=2*atan(ccd_w/(2*f))
Any help how to do it?? Part of the code above is from another post I found
in this newsgroup...
Thank you very much!!
Subject: Re: Model a real world camera
Date: 24 Jul 2005 08:35:02
Message: <dc01p9$u89$1@chho.imagico.de>
Alblurrow wrote:
> Hello,
> it.
The focal length alone does not define the field of view of the camera.
  To calculate the camera angle from the focal length and the sensor
size use simple geometry - the formula you gave is correct for normal
lenses, for others see:
http://bobatkins.com/photography/technical/field_of_view.html
'It does not work' has not much value as description of a problem.  Note
the sensor resolution is not relvant to set up the camera in POV-Ray.  See:
http://www.povray.org/documentation/view/3.6.1/246/
for the meaning of the camera parameters.
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
