POV-Ray : Newsgroups : povray.newusers : Blobs functions Server Time
18 May 2026 02:35:23 EDT (-0400)
  Blobs functions (Message 1 to 6 of 6)
Subject: Blobs functions
Date: 22 Jun 2005 04:14:34
Message: <42b91dea@news.povray.org>
Hi again,
Using this function:
#declare Blobs = function { f_blob2(x, y, z, 0.95, 4, 1.8, 1) }
isosurface {
function { Blobs(x, y, z) }
max_gradient 6
contained_by { sphere { 0, 9 } }
scale 2
rotate 75*y
translate <0, 0, 0>
pigment { color Blue }
I've here two blobs situated along the y axis. Is it anyway to give a
texture to the first and then giving another texture and color to the other
using the function?
Thanks in advance,
Oleguer
Subject: Re: Blobs functions
Date: 22 Jun 2005 08:19:59
Message: <dCrEvHApdVuCFwwj@econym.demon.co.uk>
Wasn't it Oleguer Vilella who wrote:
>Hi again,
>isosurface {
>max_gradient 6
>scale 2
>rotate 75*y
>translate <0, 0, 0>
>using the function?
You can't do it from the function itself, because the function only
thinks of the whole shape as a single primitive object. It doesn't know
that the resulting shape is going to look like two blobs.
What you can do, is to use a texture_map to apply different textures, or
a pigment_map to apply different pigments to chosen regions of the
surface, like this:
(The "0.95/2" I used is calculated to be half way to the blob separation
"0.95" specified in the first line.)
isosurface {
max_gradient 6
texture{gradient x
  texture_map {[0.5  pigment {rgb <0,0,1>}]
               [0.5  pigment {rgb <1,0,0>}]}
  translate <-0.5,0,0>   // move transition point to the origin
  scale 100              // scale up the texture_map
  translate <0.95/2,0,0> // move the transition point to half way
scale 2
rotate 75*y
translate <0, 0, 0>
Or
pigment {gradient x
  pigment_map {[0.5  rgb <0,0,1>]
               [0.5  rgb <1,0,0>]}
Mike Williams
Gentleman of Leisure
Date: 22 Jun 2005 09:51:53
Message: <42b96cf9$1@news.povray.org>
Hi Mike,
And using more than two colors?
I was reading the documentation about that. They say that:
"When the gradient x function returns values from 0.0 to 0.3 the red
highlighted texture is used. From 0.3 to 0.6 the texture identifier T_Wood11
is used. From 0.6 up to 0.9 a blend of T_Wood11 and a shiny DMFWood4 is
used. From 0.9 on up only the shiny wood is used."
I thought that number is used to divide the object in different parts, for
exemple if your are using 3 colors you can put 1/3 before the pigment
instead of the 1/2 that you've put the divide the object. But I obtain some
strange results.
texture {gradient x
 texture_map {[0.3  pigment {rgb <0,0,1>}]
               [0.6  pigment {rgb <1,0,0>}]
              [0.9 pigment { rgb <0, 1, 0>}] }
  //translate <-0.5,0,0>   // move transition point to the origin
Well, I'm not understanding it properly.
Thanks for the anwers,
Oleguer
news:dCr### [at] econymdemoncouk...
>>Hi again,
>>isosurface {
>>max_gradient 6
>>scale 2
>>rotate 75*y
>>translate <0, 0, 0>
>>other
>>using the function?
> surface, like this:
> isosurface {
> max_gradient 6
> texture{gradient x
> scale 2
> rotate 75*y
> translate <0, 0, 0>
> Or
> pigment {gradient x
>               [0.5  rgb <1,0,0>]}
> Mike Williams
Date: 22 Jun 2005 10:39:10
Message: <42b9780e@news.povray.org>
Something like this:
gradient x
texture_map {
[0.2  pigment{Red}]
[0.4  pigment { Blue }]
[0.6  pigment { Yellow}]
[0.9  pigment{Green }]}
But I couldn't undesrstand right the values that are before the pigment.
news:42b96cf9$1@news.povray.org...
> Hi Mike,
> T_Wood11 is used. From 0.6 up to 0.9 a blend of T_Wood11 and a shiny
> DMFWood4 is used. From 0.9 on up only the shiny wood is used."
> some strange results.
> texture {gradient x
> Oleguer
>>>Hi again,
>>>isosurface {
>>>max_gradient 6
>>>scale 2
>>>rotate 75*y
>>>translate <0, 0, 0>
>>>other
>>>using the function?
>> surface, like this:
>> isosurface {
>> max_gradient 6
>> texture{gradient x
>> scale 2
>> rotate 75*y
>> translate <0, 0, 0>
>> Or
>> pigment {gradient x
>>               [0.5  rgb <1,0,0>]}
>> Mike Williams
Date: 22 Jun 2005 12:13:38
Message: <4$4dQHAm4YuCFwH1@econym.demon.co.uk>
>Hi Mike,
>strange results.
>texture {gradient x
>Oleguer
One of the significant things is that you should get rid of the
"scale 100" if you want more than two bands. I just put that there so
that you wouldn't see more than two bands unless you made the blob
extremely large.
Texture_maps work just like colour_maps, so try reading that
documentation and see if it's any easier.
The basic idea is that "gradient x" sets up a *pattern* that takes the
value (x - floor(x)) at all points in space. E.g. at the point <0,1,2>
the pattern takes the value 0, and at <2.45,4,6> it takes the value 0.45
(that's 2.45 - 2.0). The pattern doesn't care where your object is, it
only concerns itself with points in space.
So, lets suppose that POVRay is tracing some object and finds a point on
the surface at <2.45,4,6>, it works out that the value of the pattern is
0.45, and looks that up in the texture_map. In your example above, 0.45
comes exactly half way between these two entries
so it renders a 50-50 blend of those two textures giving pigment
{rgb <0.5,0,0.5>}
However, when it finds a point like <3.1,3,3>, the pattern evaluates to
0.1 and that's below the first entry in the map, so POV uses the first
entry in the map.
So for three equally spaced hard-edged bands you might use
pigment {gradient x
  pigment_map {[1/3  rgb <0,0,1>]
               [1/3  rgb <0,1,0>]
               [2/3  rgb <0,1,0>]
               [2/3  rgb <1,0,0>]}
  scale 0.95*2           // scale up the texture_map to show 3 bands
  translate <0.95/2,0,0> // move the mid point texture to half way along
                         // the blob
Mike Williams
Date: 23 Jun 2005 03:41:38
Message: <42ba67b2$1@news.povray.org>
Hi Mike,
Yeah, I think I've understood it now.
pigment {gradient x
pigment_map {[0.2  rgb <0,0,1>]
               [0.4  rgb <0,1,0>]
               [0.6  rgb <1,1,0>]
               [0.8  rgb <1,0,0>]
               [1 color Yellow]}
scale 0.95*1
Let more time to practise it. I've also read that documentation and it has
more information than the other I had read.
Thank you very much for the replys,
Oleguer
"Mike Williams"says:
> extremely large.
> {rgb <0.5,0,0.5>}
> entry in the map.
> pigment {gradient x
>               [1/3  rgb <0,1,0>]
>               [2/3  rgb <0,1,0>]
>               [2/3  rgb <1,0,0>]}
>                         // the blob
> Mike Williams
