POV-Ray : Newsgroups : povray.newusers : sci-fi laser blasts Server Time
20 Mar 2026 14:03:34 EDT (-0400)
  sci-fi laser blasts (Message 1 to 4 of 4)
Subject: sci-fi laser blasts
Date: 13 Jun 2005 11:06:16
Message: <42ada0e8$1@news.povray.org>
Hi. After seeing Star Wars this past weekend, I'm consumed by the idea of
sci-fi modeling and effects. Call me a sucker for special effects. But
anyway, I was thinking of a laser blast. I managed to get a nice green laser
by using two emissive medias, one with a green cylindrical density and one
with a white cylindrical density slightly smaller than the green, all
contained in a CSG merge of a cylinder and two spheres. It looks pretty good
I think. I know that emmisive media doesn't really emit light, but I was
naively expecting that it's color would affect nearby objects when radiosity
is used, in the same way that a white sphere would pick up some green from a
green wall. in the global settings, media was set to "on".
Is the above the expected behavior of emitting media? if this is the
expected behavior, how would you go about faking a green light emitting from
the media? just attach a small light_source to the laser blast object with a
suitable fade power and fade distance?
-r
Subject: Re: sci-fi laser blasts
Date: 13 Jun 2005 14:21:55
Message: <42adcec3$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> wrote in message
news:42ada0e8$1@news.povray.org...
Hiya Ross. I still haven't seen the Episode 3 yet. Sounds like it had
something for you, at least.
> good
> radiosity
> a
Should be okay then. media on goes in radiosity block, just so you weren't
mistakenly putting it into global_settings only.
> from
> a
area_light like that could enhance it a lot, sure, but then you need to
either let it interact with the media or tell it not to.
Checking here with a test media object and radiosity I see you might need to
increase 'count' to 500 or more, especially if the laser isn't in close
proximity to the other scene objects. Perhaps even increasing 'brightness'
to more than 1. In fact, there might be other settings which could prove
better but it looks to me like a light would be less likely to cause trouble
such as radiosity can if you attempt to maximize the interactions from it
(texture tweaking, etc.).
Bob Hughes
Date: 13 Jun 2005 14:36:22
Message: <42add226$1@news.povray.org>
Hi Ross and Bob,
I saw the film the last weekend. There was a topic from the last year
here related on lasers you could search it.
Oleguer
news:42adcec3$1@news.povray.org...
>> one
>> good
>> radiosity
>> from
>> a
>> from
>> with
>> a
> to
> trouble
> Bob Hughes
Date: 14 Jun 2005 10:29:10
Message: <42aee9b6$1@news.povray.org>
"Bob Hughes" <bob### [at] charternet> wrote in message
to
trouble
> Bob Hughes
With radisotiy on, and media on in the radisotiy block, I tried a 28 frame
animation with the laser blast travelling quite close to a box. the overall
lighting of the scene does change as the object with emissive media travels,
but not in a real meaningful way. (then i spent two hours trying to get
mencoder to work properly...). It's a little hard to explain in detail, but
the increase in light doesn't obviously correspond to the movement of the
object. It's a little jumpy. There are two media statements, one uses
something like "emission <0, 1, 0>*4" and one uses something like "emission
<1, 1, 1>*8" and each have a simple cylindrical color map in their density
statements. For radiosity, I moved "count" up to 700 and generally changed
some of the values that the docs say lead to higher quality. I can't expect
much help without posting the scene, but I can't post it at the moment.
I think I'll just play with adding a lightsource that moves with the media
object. It feels like this will allow more flexibility and fine tuning.
Thanks!
