POV-Ray : Newsgroups : povray.newusers : Distorted isosurface Server Time
18 May 2026 03:52:09 EDT (-0400)
  Distorted isosurface (Message 1 to 2 of 2)
Subject: Distorted isosurface
Date: 30 Apr 2005 01:57:22
Message: <42731e42$1@news.povray.org>
	The following code creates a spiral that starts out at y = 0 at the
outer radius and gains height (y) as the radius decreases. Can anyone
suggest a way to do this without distorting the cross-section radius of
the spiral in the y direction? I'm also having trouble getting it into
an upside-down funnel shape that falls off the way I want it to (raising
it more just in the center).
isosurface {
  #declare F = function { f_spiral(x, y, z, 0.5, 0.05, 3, -0, -0, 1) }
  function { F(x, y-1/f_r(x, y/8, z), z) }
  contained_by { box { -4, 4 } }
  max_gradient 10
  pigment { rgb<1, 0, 0> }
Any help would be greatly appreciated,
Ryan
Subject: Re: Distorted isosurface
Date: 30 Apr 2005 15:50:45
Message: <5IcCcFA$E+cCFw1l@econym.demon.co.uk>
Wasn't it Ryan Twitchell who wrote:
>Hi,
>isosurface {
>  max_gradient 10
I'm fairly sure that you can't get there staring from f_spiral - it
always seems to distort the cross section when you do this sort of
thing.
I've so far not managed to find any other isosurface approach that
doesn't suffer from similar problems, so I suggest using a sphere sweep.
Unfortunately, it's slower than the isosurface you started with.
// Control parameters
#declare r_step=0.01;       // Smaller for greater accuracy
#declare a_step=70*r_step;  // Larger for more coils
#declare Thickness=0.02;    // Larger for fatter lines
#declare Steepness=4.5;     // larger for raising more in the centre
#declare Height=0.5;        // max height
#declare r=1;
#declare A=0;
sphere_sweep {
  b_spline
  r/r_step
  #while (r>0)
    ,<r*cos(A), pow(1-r,Steepness)*Height ,r*sin(A)>,Thickness
    #declare A=A+a_step;
    #declare r=r-r_step;
  pigment {rgb x}
Mike Williams
Gentleman of Leisure
