|  |  | Hi all.
I'm rather new to POV (about 1 month) and I am trying to do soft shadows.
For that, I used the area_light option. This softens the shadows, increases
the computation time, but generates a very "grainy" shadow.
Is there a trick to avoid it ?
To see the result of my first tries, look at :
http://croquis.over-blog.com/article-171375-6.html
(the texture on the wall is only a white pigment, no normal or other
effects...)
|  |  | bancquart.sebastien wrote:
> Hi all.
I'm not noticing the 'grainy' look there ... but I know the look you
mean. I found that increasing the number of lights in the area light
will give a much less grainy shadow but doesn't increase the render time
considerably.
Cheers!
> considerably.
  But only if you use adaptive supersampling (which you should, of course).
|  |  | Thanks for your help.
I tried with a huge number of lights (25*25) and it's peeeeeeeeeeerfect !
message de news:422e9814@news.povray.org...
It is not to divert you from news.povray.org , of course, but
Do you know the french speaking POV-Ray group?
news://news.zoo-logique.org/3D.Pov-Ray
In your newsreader count/server configuration  you must check "ouverture de
session requise" and
enter a user name : zoo
and a password : entrer
You are welcome :)
Marc
|  |  | I didn't know it, but will look at it. Thanksalot !
422eac62$1@news.povray.org...
> de
> You are welcome :)
> Marc
