POV-Ray : Newsgroups : povray.newusers : surface area of objects Server Time
30 Sep 2024 06:18:49 EDT (-0400)
  surface area of objects (Message 1 to 3 of 3)
Subject: surface area of objects
Date: 10 Dec 2004 15:55:33
Message: <41ba0d45@news.povray.org>
is there any simple way to let povray calculate the surface area and volume
of an object?
For example, for a buoy, whose mass depends on it's surface area, it's
displacement beneath the water surface could be calculated very easily if
there were functions to calculate the volume & surface area of the buoy in
povray.
of course I could calculate this manually also, but it would be a lot easier
if povray could do this.
Q: How many mathematicians does it take to screw in a light bulb?
A: One.  He gives it to six Californians, thereby reducing the problem
 to the earlier joke.
Subject: Re: surface area of objects
Date: 11 Dec 2004 10:21:21
Message: <cjameshuff-C31CF5.10214911122004@news.povray.org>
In article <41ba0d45@news.povray.org>,
> of an object?
> povray.
There is no easy, general method for doing so, and for some objects
there are multiple ways to define "surface area". For example, do you
count both sides of a triangle? Do you count the inner surface of an
open-ended cylinder? And how do you compute the area of a julia fractal?
Volume also has some problems...not all shapes have a finite volume, and
how do you define it for open objects?
However, given some knowledge about the object, you can use the
scripting capabilities of the POV-Ray scene description language to get
a numeric approximation. It should be pretty easy to compute both
surface area and volume for a more or less cylindrical shape with a few
loops and trace() calls, for example.
http://tag.povray.org/
Date: 11 Dec 2004 12:00:16
Message: <41bb27a0@news.povray.org>
>> volume of an object?
>> in povray.
>> easier if povray could do this.
too bad :-(
thanks.
You will be misunderstood by everyone.
