POV-Ray : Newsgroups : povray.newusers : Better way to make random sequence Server Time
20 Aug 2025 06:53:38 EDT (-0400)
  Better way to make random sequence (Message 1 to 4 of 4)
Subject: Better way to make random sequence
Date: 3 Dec 2004 12:49:44
Message: <41b0a738$1@news.povray.org>
I'm trying to create a scene which relies on the random placement/sizing
of blobs to form "rough ground".  Unfortunately, the random number
generators in Povray aren't very random (if I'm reading the help file
correctly there is just a random series of numbers that the system runs
through).  Any ways, as a result of this a pattern forms in the
topography that I am generating, and that is exactly what I'm trying to
avoid.  Has anyone out there figured out a better random-number
generator, or know of a way in which I can make pov-rays random number
generator a little more random.  Any advice (macro, code, formula or
even just ideas) is appreciated. . .
Thanx in advance
Bryan
Subject: Re: Better way to make random sequence
Date: 3 Dec 2004 13:50:02
Message: <coqcg2$gip$1@chho.imagico.de>
First of all any random number generator is just a random series of
numbers that repeat after some time.  Of course the POV-Ray rand()
function is not a very good one since like most simple random number
generators it calculates the next random number from (and only from) the
last one.  Still it is unlikely (but not impossible) that a regularity
you see is caused by the rand() function.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 3 Dec 2004 16:29:45
Message: <41b0dac9$1@news.povray.org>
"Bryan Heit" <bjh### [at] nospamucalgaryca> wrote in message
news:41b0a738$1@news.povray.org...
> Thanx in advance
I'd go with Chris on this one - and add that you should post your code. It's
easy to make mistakes with pov random number generator code that results in
regularity.
Date: 7 Dec 2004 10:55:00
Message: <web.41b5d1ead6721fe841ff36a70@news.povray.org>
You might want to adapt a more robust random stream generator if the rand()
stream is really causing you the problem.  The book "Numerical recipes in
C" has a routine for a much better (best?) uniform random deviate generator
which I have used extensively in computer simulations though never adapted
to POV's SDL.
L
