POV-Ray : Newsgroups : povray.newusers : POV-Ray rendering Server Time
20 Aug 2025 06:53:38 EDT (-0400)
  POV-Ray rendering (Message 1 to 4 of 4)
Subject: POV-Ray rendering
Date: 6 Nov 2004 14:43:17
Message: <418d2955$1@news.povray.org>
Is it possible using POV-Ray to create (relatively) the same depth of
(optical) realism achieved in the following images?:
http://www.deviantart.com/view/8446028/
http://www.deviantart.com/view/6422537/
http://www.deviantart.com/view/4328986/
Is the current version of POV-Ray comparable to mental ray in all rendering
related features?
Thank you,
William
Subject: Re: POV-Ray rendering
Date: 6 Nov 2004 15:40:02
Message: <cmjcjm$3o9$1@chho.imagico.de>
Those all are relatively unrealistic demo scenes of very low complexity.
    It is no problem to create similar images with POV-Ray.  You can
find a collection of examples of the render quality possible with
POV-Ray on:
http://www.povray.org/community/hof/
> related features?
That question does not make any sense because the answer has to be 'no'
for any two programs (just like 'Are apples comparable to peaches in all
their properties?').  You can of course do a lot of thing with POV-Ray
you can't do with mental ray.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 6 Nov 2004 16:06:25
Message: <418d3cd1@news.povray.org>
  I don't see why not.
  POV-Ray is perfectly capable of producing images like those. You just
have to know how to set the environment (ie. everything that is
reflected on the objects), the lights and the textures/interior of the
objects properly. (I would probably start with fine-tuning the brightness
of the environment and the reflection exponent and specular roughness
of the textures.)
  I have never used that (or almost any other) software, but I would
assume that it might have some pre-defined texture and scene settings
which produce that kind of images and people might get sometimes the
(wrong) idea that that software produces better images than POV-Ray
because in POV-Ray there are no such pre-defined settings and they
might not know how to set them up manually.
  In fact, I once tried to reproduce two lightflow demo images simply
by trying to match lighting brightness and textures:
http://iki.fi/warp/pics/lftest1.jpg
http://iki.fi/warp/pics/lftest2.jpg
  It's perfectly possible; it just requires perhaps more manual
fine-tuning than in the other software.
Date: 7 Nov 2004 13:37:27
Message: <418e6b67$1@news.povray.org>
William Peska nous apporta ses lumieres ainsi en ce 2004-11-06 14:39... :
blob or isosurface or mesh, photons, interior, fade_power,
fade_distance, no distersion
CSG, photons, interior, fade_power, fade_distance, no distersion
Some superellipsoids, blured reflection macro, area_light
>related features?
>Thank you,
>William
Crank up max_trace_level as needed.
