![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've done a bit of digging around and I can't seem to come up with anything.
What I'm trying to do is use HTML colours instead of RGB values. This is
really for ease of programming, to save me having to split and recalculate
the HTML values into RGB. I don't mind doing it, but is there an option to
supply POV with HTML values? Or will it need a conversion script somewhere?
Thanks,
David
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You should search this newsgroup (povray.newusers) for the topic "RGB<->HEX"
which was posted on 9/9/2004 8:33 PM.
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you mean HTML codes like "FF0088", then it's possible to write a
macro. It's not particularly pretty because you've got to perform
arithmetic on the contents of strings.
#macro HTMLRGB(H)
#local C=0;
#while (strlen(H)>0)
#local A=substr(H,1,1);
#local H=substr(H,2,strlen(H)-1);
#if (strcmp(A,"0")=0) #local C=C*16; #end
#if (strcmp(A,"1")=0) #local C=C*16+1; #end
#if (strcmp(A,"2")=0) #local C=C*16+2; #end
#if (strcmp(A,"3")=0) #local C=C*16+3; #end
#if (strcmp(A,"4")=0) #local C=C*16+4; #end
#if (strcmp(A,"5")=0) #local C=C*16+5; #end
#if (strcmp(A,"6")=0) #local C=C*16+6; #end
#if (strcmp(A,"7")=0) #local C=C*16+7; #end
#if (strcmp(A,"8")=0) #local C=C*16+8; #end
#if (strcmp(A,"9")=0) #local C=C*16+9; #end
#if (strcmp(A,"A")=0 | strcmp(A,"a")=0) #local C=C*16+10; #end
#if (strcmp(A,"B")=0 | strcmp(A,"b")=0) #local C=C*16+11; #end
#if (strcmp(A,"C")=0 | strcmp(A,"c")=0) #local C=C*16+12; #end
#if (strcmp(A,"D")=0 | strcmp(A,"d")=0) #local C=C*16+13; #end
#if (strcmp(A,"E")=0 | strcmp(A,"e")=0) #local C=C*16+14; #end
#if (strcmp(A,"F")=0 | strcmp(A,"f")=0) #local C=C*16+15; #end
#local R=int(C/256/256);
#local G=mod(int(C/256),256);
#local B=mod(C,256);
rgb <R,G,B>/255
Use it like
pigment {HTMLRGB("FF0088")}
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Williams <nos### [at] econym demon co uk> wrote:
> #local C=0;
> #end
> rgb <R,G,B>/255
> #end
Code repetition is one of the biggest sins in programming.
How about this (it has the advantage to support both uppercase and
lowercase hexadecimal numbers, ie. "c2Ab0F" is ok):
#macro HTMLRGB(H)
#local value = 0;
#local len = strlen(H);
#local index = 1;
#while(index <= len)
#local char = asc(substr(H, index, 1)) - 48;
#if(char > 9) #local char = char - 7; #end
#if(char > 15) #local char = char - 32; #end
#local value = value*16 + char;
#local index = index + 1;
<int(value/65536), mod(int(value/256), 256), mod(value,256)>
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Looks good, and only needs a couple of tiny fixes for it to give the
correct results.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> correct results.
Like what?
I know it gives garbage if you give it something else than a hex number,
but I assumed the input is always ok.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" <war### [at] tag povray org> wrote in message
news:4186b975@news.povray.org...
> > correct results.
> Like what?
Just this:
rgbf<int(value/65536), mod(int(value/256), 256), mod(value,256)>
Thanks a lot though, great script, works beautifully :)
David
[learning something new every day]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"David Robinson" <tdf### [at] ezrs com> wrote in message
news:4187b634$1@news.povray.org...
> > > correct results.
> > Like what?
number,
> Just this:
No wait, I got that wrong. After running a few values through, a lot of
colours seem to come out as white, so it must be a maths thing...?
David
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's because there really was a bug in my code. I forgot a /255.
The last line should be:
<int(value/65536), mod(int(value/256), 256), mod(value,256)>/255
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
