POV-Ray : Newsgroups : povray.newusers : Taking waay to long to render this... Server Time
11 Jul 2026 19:12:08 EDT (-0400)
  Taking waay to long to render this... (Message 1 to 3 of 3)
Subject: Taking waay to long to render this...
Date: 15 Oct 2004 02:46:07
Message: <416f722f@news.povray.org>
I made a few ojects out of glass material with photons...is this a good
idea? I chose the Crystal material from Moray, just because I dont know
what Im going in POVray with textures yet.
Its been rendering for the past half hour...and its a slice of the
original image focused on one part...Im not even using photons.
Would it be a good idea to reduce the transparency of the material in
order to speed up the rendering? I just wanted to experiment with
photons and they new 3.6 caustics, but its taking way to long to be of
any use. Would disabling radiosity be the only answer?
Any tips on improving with time?
Any help greatly appreciated.
Drey.
if anybodys curious, this is a part of waht im doing...
default {
     pigment { rgb <1,0,0> }
global_settings {
   adc_bailout 0.003922
   ambient_light <1.0,1.0,1.0>
   assumed_gamma 1.9
   hf_gray_16 off
   irid_wavelength <0.247059,0.176471,0.137255>
   max_intersections 64
   max_trace_level 10
   number_of_waves 10
   radiosity {
     brightness       3.3
     count            100
     distance_maximum 0.0
     error_bound      0.4
     gray_threshold   0.5
     low_error_factor 0.8
     minimum_reuse    0.015
     nearest_count    6
     recursion_limit  1
background { color <0.000,0.000,0.000> }
camera {  //  Camera Camera01
   location  <     -4.257,      -6.150,       5.035>
   sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
   up        <        0.0,         0.0,         1.0> // Where Z is up
   right     <    1.33400,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray) aspect
ratio
   angle          6.69718    // Vertical       5.023
   look_at   <      0.002,       0.017,       2.909>
light_source {   // Arealight Arealight001
   <0.0, 0.0, 0.0>
   color rgb <1.000, 1.000, 1.000>
   area_light <2.000, 0.000, 0.000>, <0.000, 2.000, 0.000>, 20, 20
   adaptive 1
   jitter
   scale <20.0, 20.0, 1.0>
   translate  20.0*z
light_source {   // Light001
   <0.0, 0.0, 0.0>
   translate  <-1.823118, -11.75379, 10.816377>
  #declare Crystal =
    material  // Crystal
       texture
          pigment
             color rgbf <0.98, 0.98, 0.98, 0.9>
          finish
             ambient 0.1
             diffuse 0.1
             phong 1.0
             phong_size 100.0
             specular 0.8
             roughness 0.0003
             reflection 0.1
       interior
          ior 1.45
#declare checkers =
    material  // checkers
       texture
          pigment
             checker
                color rgb <1.0, 1.0, 1.0>
                color rgb <0.0052, 0.0052, 0.0052>
box { // Cube001
   <-1, -1, -1>, <1, 1, 1>
   material {
     checkers
   scale <10.0, 10.0, 0.25>
   translate  -0.25*z
#include "pawn.in1"
#declare RotSweep001 = object {
   RotSweep001_Raw
union { // CSG001
   sphere { // Sphere001
     <0,0,0>,1
     scale 0.4
     translate  3.2*z
   object { RotSweep001 }
   material {
     Crystal
Subject: Re: Taking waay to long to render this...
Date: 15 Oct 2004 03:38:30
Message: <416f7e76$1@news.povray.org>
Hi!
> idea?
Rendering something with POV-Ray is always a good idea :)
That won't help in most cases: What makes reflection and refration so
time-consuming is that POV-Ray has to shoot both a new ray for the
reflection and the refraction. That does not depend on how transparent
the object is (only if it *is* transparent). So both
pigment { rgb <1,1,1> transmit 0.9 }
and
pigment { rgb <1,1,1> transmit 0.1 }
will render with the same speed.
There's one setting, though, were this could make a difference:
adc_bailout, which basically says that if the change in color
contributed by the additional refracted ray is smaller than the given
threshold, no more "refractive rays" will be shot (for that pixel).
I'm no pro with radiosity, but you got both radiosity and area lights in
your scene, and those are among the big render-time-killers (other
candidates are photons and isosurfaces). Perhaps you can either go with
less radiosity quality (see rad_def.inc for some examples) or replace
that area light by a normal point/spot-light.
With a scene as simple as yours, the things I mentioned above are
perhaps everything you can do. One must-read-tutorial about rendering
speed is Mike's Holes Tutorial:
http://www.econym.demon.co.uk/holetut/index.htm
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 15 Oct 2004 10:25:07
Message: <416fddc3@news.povray.org>
"Soace Munky" <alu### [at] gmailcom> wrote in message
news:416f722f@news.povray.org...
> Drey.
as Florian said, radiosity and area lights are big time consumers. If using
radiosity, i'd just use a regular point light for now. Then add it back in
later if you still want it.
