POV-Ray : Newsgroups : povray.newusers : no_reflection with fog Server Time
22 Dec 2025 02:04:39 EST (-0500)
  no_reflection with fog (Message 1 to 4 of 4)
Subject: no_reflection with fog
Date: 24 Sep 2004 18:59:49
Message: <4154a6e5$1@news.povray.org>
How does one specify the no_reflection option to a fog?
I have a white, reflective plane with an object above it.
In the background is a blue "wall" of fog (ground fog that is rotated).
The shadow of the object on the white plane appears blue because the
plane is reflecting the blue fog "wall".
I want the shadow to be gray as opposed to blue.
I was advised in the irc.freenode.net #povray channel to use
no_reflection, but povray 3.6.1 complains when trying to use this in the
fog.
In addition, object { fog { ... no_reflection } } causes an error
because fog is not an object, I guess... which is probably why it
doesn't accept the no_reflection option either.
I was thinking of having a second, transparent plane slightly above
the white, reflective plane that did not transmit blue light... but
this would have the unintended consequence of filtering the
blue light from the reflection of the object hoving above the plane too.
Any suggestions?
Subject: Re: no_reflection with fog
Date: 25 Sep 2004 11:06:41
Message: <41558981$1@news.povray.org>
mntorrent nous apporta ses lumieres ainsi en ce 2004-09-24 18:42... :
> the fog.
> Any suggestions?
You can replace your fog by a media filled box, the box been given the
no_reflection. The render time may be longer.
Date: 25 Sep 2004 11:39:30
Message: <41559132$1@news.povray.org>
You could try adding the metallic keyword to the reflection of the
plane, like that: reflection { yourvalues metallic }
This will color the reflections in the color of the plane's pigment...
HTH,
Florian
The man who strikes first admits that his
ideas have given out. (Chinese Proverb)
[------------ http://www.torfbold.com - POV-Ray gallery ------------]
Date: 26 Sep 2004 00:35:59
Message: <4156472f$1@news.povray.org>
I ended up adding another plane perpedicular to the floor
several units behind the object but very much in front of the
blue fog wall.
This plane is not rendered and does not cast shadows, but it
is reflected by other surfaces.
The definition of this plane is
plane
      locationv-look_atv, -6
      texture { pigment{color rgbft <0,0,1,1,1> } }
      no_image  // DON'T ACTUALLY RENDER THE PLANE
      no_shadow // DON'T EVEN LET THE INVISIBLE PLANE CAST SHADOWS
      // no_reflection // WE ARE GOING TO LET THE PLANE BE REFLECTED
The relfected pigment of this plane seemed to nearly cancel out
the blueness of the fog on the surface of the white plane...somewhat.
> fog.
> Any suggestions?
