POV-Ray : Newsgroups : povray.newusers : Double like a bridge Server Time
30 Sep 2024 10:19:22 EDT (-0400)
  Double like a bridge (Message 1 to 6 of 6)
Subject: Double like a bridge
Date: 2 Sep 2004 06:05:49
Message: <4136f07d@news.povray.org>
Hello all,
I'm traying to double this objecte like a bridge, but I only want to double
in the middle of it, the extremes should be straights. I don't know who can
I do it. Can anyone help me?
The code is:
#include "textures.inc"
camera { location <0, 0, -23> look_at <0, 0, 0> focal_point <-15, -9, 0> }
light_source { <-5, 2, -15> color rgb <2, 2, 2> }
light_source { <10, 2, 0.> color rgb <1, 1, 1>  }
background { color White }
#macro Cuc (How_many_blobs)
#local HM_Blobs_remanente = How_many_blobs ;
blob {
threshold .6
#while (HM_Blobs_remanente>0)
sphere { <0, HM_Blobs_remanente*1.2 ,0> 1 , 1 }
#local HM_Blobs_remanente = HM_Blobs_remanente-1 ;
scale 0.5
pigment { Gray*0.75 }
finish { phong .4 }
object { Cuc (8) rotate z*105 translate <-8, -5, 0>  }
Thanks in advance,
Oleguer
Subject: Re: Double like a bridge
Date: 2 Sep 2004 12:19:30
Message: <41374812$1@news.povray.org>
you canscale the same object by -x. This will mirror the object in the YZ
plane.
object { Cuc (8) rotate z*105 scale -x          translate <-8, -5, 0>  }
Greetings
JWV
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:4136f07d@news.povray.org...
> Hello all,
double
can
> The code is:
> blob {
> threshold .6
> #end
> scale 0.5
> finish { phong .4 }
> #end
> Thanks in advance,
> Oleguer
Date: 2 Sep 2004 14:17:32
Message: <413763bc$1@news.povray.org>
No, maybe my explanation wasn't correct.
I want to turn it like a bridge, I want to make and angle in the middle of
the object and keep the ends of the object straight.
Well I thinks thats better than the other.
Thanks,
Oleguer
news:41374812$1@news.povray.org...
> plane.
> Greetings
> JWV
> > Hello all,
> double
> can
> > The code is:
0> }
> > blob {
> > threshold .6
> > #end
> > scale 0.5
> > finish { phong .4 }
> > #end
> > Thanks in advance,
> > Oleguer
Date: 2 Sep 2004 15:19:55
Message: <4137725b$1@news.povray.org>
you mean you want to bend it in the middle? For as far as i know, you can
not do this without using the bend macro. But i can't find that macro at the
moment, sorry.
JWV
news:413763bc$1@news.povray.org...
> Thanks,
> Oleguer
YZ
> > plane.
> > Greetings
> > JWV
> > > Hello all,
> > double
who
> > can
> > > The code is:
> 0> }
> > > blob {
> > > threshold .6
> > > #end
> > > scale 0.5
> > > finish { phong .4 }
> > > #end
> > > Thanks in advance,
> > > Oleguer
Date: 2 Sep 2004 15:49:41
Message: <41377955$1@news.povray.org>
double
can
If I understand the effect you're going for, you might be able to place the
spheres in a parabolic shape (this code hasn't been tested):
#declare Bridge_Width = 5.0; // set to whatever
#declare Bridge_Height = 2.0; // set to whatever
 #local blobnum = HM_Blobs_remanente - 1; // (easier to start with index 0)
 #local blobamnt = blobnum / (How_many_blobs-1) // (number from 0.0 to 1.0)
 #local blobamnt = blobamnt * 2.0 - 1.0; // (now from -1.0 to 1.0)
 sphere { <blobamnt * Bridge_Width*0.5, (1-pow(blobamnt,2)) * Bridge_Height,
0> 1 , 1 }
This will place the spheres along a curved path from <-Bridge_Width/2,0,0>
to <0,Bridge_Height,0> to <Bridge_Width/2,0,0>.
The tricky part is the (1-pow(blobamnt,2)), which takes a number from -1 to
1 (which represents how far across the bridge the current blob sphere is),
squares it (to get a number from 0 to 1, higher at the edges of the bridge)
and then subtracts that from one (to get a number from 0 to 1, now lower at
the edges of the bridge).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 2 Sep 2004 17:24:41
Message: <41378f99@news.povray.org>
Hi Slime,
Your code gives a parse error here: "#while (HM_Blobs_remanente>0)". I'm
traying to find out the reason.
Don't worry about that JWV.
Thank you,
Oleguer
news:41377955$1@news.povray.org...
> double
> can
the
0)
1.0)
Bridge_Height,
> 0> 1 , 1 }
> #end
to
bridge)
at
>  - Slime
